How to: Convert ONAN CCK & MCCK 6.5KW to OEM Electronic Ignition
this thread has 51 replies and has been viewed 73414 times
Old 07-07-2017, 10:42:18 PM
DannoGA DannoGA is offline
Default Re: How to: Convert ONAN CCK & MCCK 6.5KW to OEM Electronic Ignition
Greetings Ken. I have the same model Onan generator you have. Did you ever complete the conversion to electronic ignition? Any information that might help me get to the conversion process is greatly appreciated.
Old 06-25-2018, 12:32:10 PM
cmslaght cmslaght is offline
I just wanted to pass on my thanks to the people in this forum. I have owned my boat (1981 33' Bertram) for about 7 years and from day 1 my Onan MCCk 6.5k never worked well.
Found that the heating element in the choke box was broken so the choke wasn't right which made starting difficult. Then the generator would run for a while and then start to hunt and pop till it would either stall or I would stop it.
After upgrading the ignition to the EIK and replacing the plugs, wires and coil with the modern Onan version thats posted here, the generator actually runs great and does not hunt anymore.
I suspect now that the coil was bad and when it would get hot it would start messing up.
Some notes:
I used the part numbers found in this forum. My EIK came with the gasket and the mount piece (which you still have to cut the nub off of). I did not trim down the EIK since I used the box it came with which mounts great.
Whole thing only took me about an hour to install (if that).
Many many thanks.. Even though this is many years old, its still helping people like me!!
The Following 2 Users Say Thank You to cmslaght For This Post:
Trying to convert to Electronic ignition w/Magna Arc jwrape Onan Generators 61 08-06-2008 01:25:58 PM
electronic ignition Alan R Small Air Cooled Gasoline Engines 5 05-03-2007 08:49:23 PM
Electronic Ignition Gunny Onan Generators 22 01-31-2007 07:21:48 AM
Electronic ignition for Onan BF-MS 3271E lwhiway Small Air Cooled Gasoline Engines 0 09-13-2006 04:01:49 PM
Need a electronic ignition for IH Tractor Kevin M. Antique Engine Archives 1 03-20-2003 03:31:21 PM
