Onan Production Orders and Wiring Drawings Available
this thread has 107 replies and has been viewed 64144 times
Closed Thread
Old 02-18-2009, 01:50:59 PM
W Smith W Smith is offline
Default Re: Onan Production Orders and Wiring Drawings Available
Any info that you could supply on Onan generator 15JC-5DR31/342P SER # 56C892454 and the Automatic Transfer switch ATUE C60-3D 1293 would be very much appreciated.
Bill Smith
nevland@cwnet.com
Old 02-18-2009, 04:01:13 PM
H M Hartman H M Hartman is offline
Jim, I sent you a PM yesterday, still need wiring diagram for 1956 Onan if you can help.
Model#3DSP3R/1R
AC 115-230 3KV 3000KW
P/f-1 13 AMP
SER#116B553152
GEN# 473279
DATA#3DSP3C1B-1800RPM
Old 02-18-2009, 05:41:34 PM
Dave Edmonds Dave Edmonds is offline
See what you started, Jim!! Offer a little information and everybody wants it! Sounds like you have a wealth of information on the CD's.
Dave Edmonds
Old 02-18-2009, 07:58:10 PM
Dasher Dasher is offline
Would love to get a wiring diagram for a 17.5 kw RDJF-3CR/1AC , also have the ser # C820613404 and would like to know the year it was made or any other interesting info
Thanks,
Old 02-18-2009, 08:05:18 PM
BTPost's Avatar
BTPost BTPost is offline
Images: 1
Talking Re: Onan Production Orders and Wiring Drawings Available
Bill Smith, you have a 15Kw, J Series, Gas or Gasoline Powered, Spec P, 4 Cyl Onan Genset. It is fitted with a Magniciter Genend, wound for 240 Vac 3 Phase Delta, with a 120/240 Center Tapped Winding, and 240 Vac High Leg. It has Remote Start Capability. This information is available in the Onan FAQ at the TOP of the Onan Forum Thread List.
Bruce in alaska
Old 02-19-2009, 05:04:10 AM
Rick Francis Rick Francis is offline
wireing 4 onan mod#nhc-ms/2570c ser#h763197188 thanks
Old 02-19-2009, 07:36:18 AM
Patrick Patrick is offline
Jim, one I doubt you'll be able to find anything on -
a 1944 Model 48S-6
Serial 84.195291
SAE 10 oil
An AC voltage section, left blank.
Power factor, cycles,, phase - again left blank.
DC - volts 12/15
Amps - 30
RPM - 2000
Watts - 4000
Gen No. 192142
Gen Data 337
12 volt battery used
Thanks for trying!
Old 02-20-2009, 10:23:06 PM
Jim Davis Jim Davis is offline
Guys I just got back on this after a tough week on the job. Looks like I am going to be behind for a while. I also have PM's that are not on the thread so bear with me. I will get to them all eventually.
The Following 3 Users Say Thank You to Jim Davis For This Post:
Old 02-23-2009, 08:14:51 PM
2300ford 2300ford is offline
I would very much appreciate having the wiring diagrams for a
4.0bf-3cr/16000b
C760110920
I bought one that someone removed the starter solenoid from and I need to reinstall one (correctly) to get it running again
Thanks much
Old 03-09-2009, 02:37:43 PM
Isaac-1 Isaac-1 is offline
Jim, I have one more for you
125.0DYD-15R / 19437H
SN E800502934
Specificly I am looking for coolant heater voltage as the name plate is unreadable. Any other info you have would be most helpful as well.
thanks Ike
Closed Thread
Onan 12JC-5DRV/166P drawings needed BergmanJ Onan Generators 19 07-04-2009 06:52:12 PM
Onan DJC wiring id Jdnutinwa Onan Generators 3 10-07-2008 11:32:43 PM
Onan CCK wiring sam c Onan Generators 2 06-23-2008 01:33:06 PM
