Onan CCK Manifold Restoration
this thread has 13 replies and has been viewed 26767 times
Old 10-20-2009, 01:44:45 AM
OnanParts's Avatar
OnanParts OnanParts is offline
Default Onan CCK Manifold Restoration
First pic is of the Onan CCK intake/exhaust manifold before I attacked it! Second pic is after a few spins in the Steelabrator. What's a Steelabrator? It's a really nice tool for cleaning cast iron using millions of super small steel buckshot. Third pic shows a few thousand of them inside the carb port. Fourth pic you can see the impeller blades that spin the shot around the manifold that is mounted to the cage that rotates.
But wait! How did you get those rusted tight exhaust pipe nipples out? Well, you sure don't try and remove them cold! HEAT! Lots of it! Small propane torch ain't gonna do it! Get a real torch and heat up the area where the threads are on both the pipe and manifold a dull cherry red. Get the manifold glowing nice before hitting the pipe with the torch, it will take a few minutes. Get that sucker glowing real nice but not so you start melting it! Shut off the torch and get a nice grip on the nipple with a vise grip and see if it will turn. It should let go, keep turning it unless it gets tight. Work it back and forth until it comes out. You may have to heat it up again and repeat. Don't force it! Unless you want to have a two or three piece manifold...
Up next Mr. Milling machine...
ID:	65263   Click image for larger version
ID:	65264   Click image for larger version
ID:	65265   Click image for larger version
The Following User Says Thank You to OnanParts For This Post:
Old 10-20-2009, 01:53:30 AM
OnanParts's Avatar
Default Re: CCK Manifold Restoration
Bottom side I milled the gasket surfaces first.
ID:	65270   Click image for larger version
ID:	65271   Click image for larger version
Old 10-20-2009, 01:59:02 AM
OnanParts's Avatar
Top side next. The exhaust flanges were pitted pretty good.
ID:	65277   Click image for larger version
ID:	65278   Click image for larger version
Old 10-20-2009, 02:04:20 AM
OnanParts's Avatar
But they cleaned up nice. This manifold did not have both sides drilled and tapped for flange style exhaust so I took care of that problem.
ID:	65280   Click image for larger version
ID:	65281   Click image for larger version
Old 10-20-2009, 02:09:01 AM
OnanParts's Avatar
Almost done. The vacuum port was already there and plugged but I'll have to drill and tap the mounting hole for the vacuum assist booster used on some models.
Old 10-20-2009, 10:18:12 AM
Dave Edmonds Dave Edmonds is offline
Nice looking work!
My dad was in the structural steel business and had a "wheelabrator" - could blast 24" tall steel beams down to white metal in a continuous process - beam went in one side and out the other. They fabricated quite a bit of steel for NASA that required that level of cleaning (never understood quite why that level - most of it was in the structure of buildings). The steel had to be primed within a few minutes or it would start to rust.
Dave Edmonds
Old 10-20-2009, 10:32:17 AM
OnanParts's Avatar
The machine I have access to will do about a 2' long piece. Cast iron or thick steel. I spray parts down with wd40 if I don't plan on painting ASAP. That old rust will come back really fast!
TJ
Old 11-02-2009, 12:26:10 AM
OnanParts's Avatar
Found another CCK manifold to restore. This one the prior owner attempted to remove the rusted/frozen muffler flange bolts cold and busted the ear off one side. They stopped while they were behind. I used high heat on the other side and removed those bolts without causing any damage. This manifold is a perfect example of why you want to use heat instead of trying to force a frozen or rusted exhaust bolt off cold.
Welding cast iron is an art best left to those who do it well. I'm lucky that there is a really good cast iron welder local with a walk in oven he uses to weld up cast heads, manifolds etc. He'll pick this one up next week and when I get it back I'll put it on the mill and return it to where it is like new again. More pics on that part of the resto soon.
TJ
ID:	66137   Click image for larger version
ID:	66138   Click image for larger version
ID:	66139   Click image for larger version
Old 11-02-2009, 03:23:17 AM
OnanParts's Avatar
Short video showing the removal of a frozen/rusted exhaust bolt on the CCK manifold via the proper "heat" method. If the bolt does not turn free as shown here the first time don't force it. Reheat and try again. Don't melt the manifold! Get it glowing cherry red hot around the whole area of the bolt. Once you put a vise grip or in this case a socket on the bolt head it will cool the head just enough to keep it from twisting off as long as you wait a few seconds before trying to remove it. Manifold hot, bolt not quite as hot is the key or you will twist the head or what's left of a stud off and really be screwed!
TJ
http://www.youtube.com/watch?v=lYSZncjnzVs
Old 11-30-2009, 11:31:36 PM
OnanParts's Avatar
Second CCK manifold has returned from the walk in welding oven. Broken ear has been built back up and the other threaded flange mount hole was filled in since the threads were looking pretty bad. In the next few days Mr. Steelabrator for some final cleaning and then off to the milling machine.
TJ
ID:	68295   Click image for larger version
Onan 6.5 NH flooding / wet manifold TheWauk Onan Generators 14 05-09-2011 02:15:09 PM
Onan 5.0 CCK intake manifold problems D Sellers Onan Generators 2 12-31-2010 09:18:45 PM
Onan 5.0 CCK Intake Manifold Leak Robert S. Onan Generators 9 07-16-2010 03:08:30 PM
Onan JC exhaust manifold Kyle K Onan Generators 2 05-31-2010 10:36:01 PM
Onan Manifold on Welder WildWillie Onan Generators 4 01-28-2010 08:48:12 AM
