Onan CCK Manifold Restoration
this thread has 13 replies and has been viewed 27044 times
Old 02-01-2010, 04:48:01 AM
OnanParts's Avatar
OnanParts OnanParts is offline
Default Re: CCK Manifold Restoration
Well it took awhile to get around to finishing up the second manifold but I had a few hours today to button it up. Turned out ok.
TJ
ID:	72764   Click image for larger version
The Following 2 Users Say Thank You to OnanParts For This Post:
Old 12-27-2011, 12:38:57 AM
lijobi lijobi is offline
I used Onanparts' heating method on a MCCK manifold with 2 broken bolts. It worked perfectly. Fortunately, there was enough of the stud left to grab on to. Definately need an acetylene torch to do this, though. Thanks for the tip.
Old 05-22-2014, 10:57:08 AM
alexn20 alexn20 is offline
Thumbs up Re: Onan CCK Manifold Restoration
Beautiful!
Old 05-22-2014, 11:47:34 AM
grif grif is offline
Default Re: Onan CCK Manifold Restoration
Walk in oven. Wow. I've done a couple of small cast items with nickle rod with the item sitting on bricks and heating with a torch, doing a "spot weld", and back with heat and peening,,, and just back and forth to fix the crack. Had good luck with the small stuff.
The thing that always bothers me, the finish after it's done. Not wanting to hide the fact that it was a repaired part,,, but that bead machine sure makes things look nice and factory new! Gotta find a small shop around here that has one.
TJ
So how do you set the work up to get both flanges on the same plane? Just set up the undamaged one level and cut the repair to match then do a cleanup cut on both of them?
Onan 6.5 NH flooding / wet manifold TheWauk Onan Generators 14 05-09-2011 02:15:09 PM
Onan 5.0 CCK intake manifold problems D Sellers Onan Generators 2 12-31-2010 09:18:45 PM
Onan 5.0 CCK Intake Manifold Leak Robert S. Onan Generators 9 07-16-2010 03:08:30 PM
Onan JC exhaust manifold Kyle K Onan Generators 2 05-31-2010 10:36:01 PM
Onan Manifold on Welder WildWillie Onan Generators 4 01-28-2010 08:48:12 AM
