Onan xDJA Injector Pump Teardown
this thread has 2 replies and has been viewed 15972 times
Old 05-04-2010, 08:33:09 PM
BTPost's Avatar
BTPost BTPost is offline
Images: 1
Talking Onan xDJA Injector Pump Teardown
This is a set of Jpeg's that one of our Resident Smartguys (Mark <mjsbv>) put together showing the complete Tear-down and Reassembly of the Injector Pump for any of the xDJA, single cyl, Onan Engines, and Gensets. So Thanks to Mark, <mjsbv> for this fine work....
ID:	78398   Click image for larger version
ID:	78399   Click image for larger version
ID:	78400   Click image for larger version
ID:	78401   Click image for larger version
ID:	78403   Click image for larger version
Bruce in alaska
The Following 2 Users Say Thank You to BTPost For This Post:
Old 05-04-2010, 08:45:05 PM
Mikey4026's Avatar
Mikey4026 Mikey4026 is offline
Default Re: Onan xDJA Injector Pump Teardown
Did you fix your's Bruce?
Mikey
Old 06-04-2010, 07:54:12 AM
BrainAllinger BrainAllinger is offline
PLB and PLB1A injector pump service manual and parts list are available at
http://www.ambac.net/images/plb.pdf
http://www.ambac.net/images/plb1a.pdf
I think the injector and nozzle are also covered there.
http://www.ambac.net/E64A353CC6034BE...71FD30F2F6.asp at bottom of page.
The Following User Says Thank You to BrainAllinger For This Post:
Onan XDJA Gen End type? Ted_Cool Onan Generators 4 04-12-2010 09:10:11 PM
Onan 2.8KV Teardown to remove carb - help! Orie Onan Generators 1 08-06-2009 06:54:27 PM
No fuel from Injector Pump, MEP002 Onan Genset hurst01 Onan Generators 15 06-15-2009 01:05:52 PM
Onan 6.0DJB-3CR/1S injector pump timing fastrick88 Onan Generators 8 05-29-2008 10:17:47 PM
Onan Injector pump needed /military genset 5dollarjoe Onan Generators 3 06-20-2005 04:03:15 PM
