Onan Electronic Ignition and TriFuel... How To
this thread has 58 replies and has been viewed 30693 times
Old 05-13-2010, 01:11:59 PM
bobbyz72 bobbyz72 is offline
Default Onan Electronic Ignition and TriFuel... How To
Bt told me a while back if i would do a step by step how to, he would post it as a stickly. Well, I have a 5.0 CCK 1975 onan generator, the points have been acting up. So i will be taking pictures of step by step, and giving the best info i can of how to up grade it to electronic ignition, and how and were to drill and tap the carburator for natrual gas or propane/ tri fuel. Im going to do all of this with only BASIC HAND TOOLS, and using the easly ways possable to do this upgrade. No fancing machining, no fancy tools, nonthing expesive, as i normaly like to do. Pictures and step by step later today....
The Following 2 Users Say Thank You to bobbyz72 For This Post:
Old 05-13-2010, 01:35:41 PM
BTPost's Avatar
BTPost BTPost is offline
Images: 1
Talking Re: Electronic Ignition and TriFuel.. How Too
Way cool, Looking forward to seeing your Product when you get it done. It will make a fine addition to the Stickys at the top of the Forum.
Bruce in alaska
Old 05-13-2010, 03:02:57 PM
DaGr51 DaGr51 is offline
Default Re: Electronic Ignition and TriFuel.. How Too
Yes, indeed! Can't wait to see this, Bobby.
Old 05-13-2010, 08:13:42 PM
K D Redd K D Redd is offline
Bobbyz72
Looks like you are going to beat me to this. I am cover-up with lawn mower and I have not done this to my 4.0 CCK. I do have it set-up gaseous fuel.
Kent
Old 05-13-2010, 10:49:03 PM
Ok, i guess to get started, we are doing this the easyest way possable, you will need 166-0767 Electronic Ignition Rotor, about $5 on ebay, 166-0785 Ignition Module, Around $20 on ebay, 515-0284 Flywheel Key, $1 used on ebay. onan timing gear front cover with the 2 screw holes for the module, about $10 on ebay. 103-0810 Timing Cover Gasket about $10, and 509-0040 Oil Seal Timing Cover End, again, about $10. Thats all the onan parts you need for this entire project.
Geting started remove all sheet metal off the front of the generator, including the fly wheel.
Step 2, grind off the square heads off the new and old governor shafts. If your new timing cover has the same governor shaft you can skip this part, see picture of me detail. After grinding off the square head work the governor shaft off, should come right off with a little force. You should have a nice square end on your governor shaft after you remove the governor arm.
Step 3, If your doing this with a NH 6.5, BFA, Skip this step. If your doing this with a cck, you will have to grind about 1/4 inch off the inside shaft part of the flywheel, it grinds down REALLY easy! If you dont do this, when you install the rotor, and flywheel and tighten down on the flywheel, if till push in oil seal inward.
More to come tomorrow, had to work 4 hours long then i had planed today.
ID:	79010   Click image for larger version
ID:	79021   Click image for larger version
ID:	79022   Click image for larger version
Old 05-14-2010, 08:15:11 PM
Ok, where were we? Go ahead and tack weld your old governor arm on to the the new governor shaft, takes about 1 second..
Step 5, install the new timing gear cover on to the generator.
Step 6, Skip, this step if doing this on a 6.5 NH or BFA.... take the new key, and cut 1/4 inch off of it, i used vice grips to be sure i didnt cut too much off. I also used a band saw, you can use what ever you want to cut it. Make sure when installed, it does not ride on the oil seal.
Step 7, install new key, slide rotor trigger on shaft, and install ignition pick up.
Step 8, tie low oil pressure into black wire.
Step 9, Use antiseize on shaft and resinstall flywheel.
Step 10, run wires, and tire red wire to Ignition coil (+), and black wire to Ignition coil (-).
Removing points box optional.
ID:	79049   Click image for larger version
ID:	79050   Click image for larger version
ID:	79051   Click image for larger version
Old 05-14-2010, 08:17:11 PM
Had to open new window to add more pictures....
ID:	79053   Click image for larger version
ID:	79054   Click image for larger version
ID:	79055   Click image for larger version
The Following User Says Thank You to bobbyz72 For This Post:
Old 05-14-2010, 08:21:53 PM
Now lets see what we can do with the carb. On the rear of the carb, there is a plug, looks like a perfect drilling location. After drilling, i ran a 1/8 NPT pipe tap into drilled hole, the carb is soft aluminum so it taps really easy.
Will reinstall carb tomorrow, and show how to set up fuel supply tomorrow.
ID:	79057   Click image for larger version
ID:	79058   Click image for larger version
ID:	79059   Click image for larger version
Old 05-14-2010, 09:15:23 PM
Ted_Cool Ted_Cool is offline
Lookin good!
The two different governor arms look compatible. Was there something interfering that made you need to change them?
Old 05-14-2010, 09:26:50 PM
Its off set a little bit, and would require tighting the governor spring a lot, and still may not be tight enough, but your right, it MAY work fine.
Tomorrow ill also measure the diffrences between the new and old gear cover, so if one would want to, you could just drill holes in your exsisting cover, and not have to buy a new one. You would just have to seal the holes up so oil wont leak out.
OEM Electronic Ignition for Onan AJ redrockx Onan Generators 24 05-06-2017 04:38:13 PM
My Electronic Ignition for Onan 4 CCK K D Redd Onan Generators 39 06-30-2012 11:42:40 PM
Onan Electronic Ignition Cruiser Onan Generators 3 10-18-2010 10:31:01 AM
Onan electronic Ignition conversion ? NF BF GHanners Onan Generators 2 09-19-2009 07:40:49 AM
Electronic ignition for 4kw BH-series Onan gkitf16 Onan Generators 5 03-15-2009 02:14:35 PM
