Onan Electronic Ignition and TriFuel... How To
this thread has 58 replies and has been viewed 30800 times
Old 05-15-2010, 09:05:44 PM
bobbyz72 bobbyz72 is offline
Default Re: Electronic Ignition and TriFuel.. How To
Originally Posted by lijobi View Post
Maybe it needs to somehow stick into the venturi which could help with the vacuum signal reguired by the demand regulator.
I have more then enough vacuum, as i can stall the engine with too much fuel if i wanted to. I am in the tightest part of the carb, so the vacuum is a peak. Maybe my natural gas is just low octane.
Old 05-16-2010, 05:16:18 AM
lokay5's Avatar
lokay5 lokay5 is offline
"Maybe it needs to somehow stick into the venturi which could help with the vacuum signal reguired by the demand regulator."
Ya think?
Because that's the way Onan does it. But what do they know?
Old 05-16-2010, 03:12:15 PM
K D Redd K D Redd is offline
I used the upper boss in the carb on my 4.0 CCK for the LP stub.
Also when I get the time, the electronic ignition system I am going to use/design will uses COMMONLY available parts that most likely WILL NOT come out of ONAN parts boxes or salvaged engines.
I just have to get ahead of the work other people are showing up with. A guy brought me a 150 amp Lincoln A.C. welder/ 4000 watt A.C. generator that he bought as a GOOD unit. He needed to use it and could not get it to work. I found the rotor OPEN. I need to get it apart and see what a re-wind will cost.
Kent
Old 05-16-2010, 08:02:52 PM
Just so all know, all the ignition parts i used are very common parts. Very easy to find, and cheap to buy. All parts total well under 60 dollars, since they are onan parts under an 1 hour to do ignition upgrade..
Old 04-25-2011, 09:30:53 PM
c east c east is offline
Thank you I was going to buy a propane conversion kit for over $200...Charlie
Old 04-25-2011, 10:22:30 PM
here you go... http://www.pngtechnologies.com/Generic_Impco.html order G-SE-KN-2 AND G-SE-43EB-PE Heres a video of ONE of my cck's... http://www.youtube.com/watch?v=SUrjXyczPuI Have any questions let me know..
Old 02-24-2012, 02:48:35 PM
lwwluke lwwluke is offline
Did this require you to set the timing? I did not see any mention of that. I also wonder if this system could be a used as a speed sensor?.
Old 02-24-2012, 06:43:34 PM
DaGr51 DaGr51 is offline
That's the beauty of this - no more need to adjust the timing, which was always a pain.
Old 03-28-2012, 09:23:47 PM
Lee Scatman Lee Scatman is offline
Thanks for the thread, it is very helpful. Looking at my governor shaft, it seems I can just remove the two screws holding the fork on, and I can swap the governor shafts betwixt the two covers without the grinding and welding. Or am I missing something?
Old 03-29-2012, 09:29:52 AM
lijobi lijobi is offline
Default Re: Onan Electronic Ignition and TriFuel... How To
Just swapping the shafts will depend on the configuration of your original. There were some variations at the bottom end or the shaft. Some were made to fit in a small needle bearing, some for a larger needle bearing, and some used no bearing. You might get lucky and it fits right in. Pay attention to the small ball bearing that goes in the hole, under the shaft as it is easily lost. Ask me how I know...
The Following User Says Thank You to lijobi For This Post:
OEM Electronic Ignition for Onan AJ redrockx Onan Generators 24 05-06-2017 04:38:13 PM
My Electronic Ignition for Onan 4 CCK K D Redd Onan Generators 39 06-30-2012 11:42:40 PM
Onan Electronic Ignition Cruiser Onan Generators 3 10-18-2010 10:31:01 AM
Onan electronic Ignition conversion ? NF BF GHanners Onan Generators 2 09-19-2009 07:40:49 AM
Electronic ignition for 4kw BH-series Onan gkitf16 Onan Generators 5 03-15-2009 02:14:35 PM
