Onan Electronic Ignition and TriFuel... How To
this thread has 58 replies and has been viewed 30694 times
Old 11-17-2012, 12:48:07 PM
AndersonMillTexas AndersonMillTexas is offline
Default Re: Onan Electronic Ignition and TriFuel... How To
Greetings everyone,
Thank you for your assistance. Cleaning and adjusting the plugs got the engine to start.
However, i must splash gasoline in the carb to get it to run and it will only stay running until the splash is used up.
Back to the manuals!!!!!
Old 03-21-2014, 10:29:00 PM
Weasel Weasel is offline
I reading complete details on main gaseous jet and understand it all, but the details on the idle tube going to front of carb.My question is about where the idle tube connects and if drilling is required;Which direction, how deep.I see a landing beside soline run jet opposite the idle screw.Anyone out there w/this factory carb(tri-fuel) I'm lookin
Old 10-30-2015, 02:29:18 PM
johngubler johngubler is offline
Default Re: Electronic Ignition and TriFuel.. How To
I'm new here so go easy on me I have ordered all the parts to convert an onan cckb engine to electronic ignition my question is do I need to upgrade the coil as well or will the original coil that was used for the points ignition work for the electronic ignition thanks for the help and for the fantastic write up on this subject. for whatever it's worth the Onan engine is from a Fairmont Mt-19 rail speeder
Old 10-30-2015, 05:46:08 PM
MBB MBB is offline
If your following Bobby instructions no need to change the coil.
The Following User Says Thank You to MBB For This Post:
  #55
Old 01-20-2016, 03:35:25 PM
although the original 6 volt coil worked I ended up upgrading to a later 12 volt coil to simplify things I'm guessing it puts out a stronger spark as well in any case the conversion went well
Old 02-25-2016, 10:24:40 AM
don theroux don theroux is offline
Will this procedure work on a 1988 6.5 MCCK
Old 07-21-2017, 12:32:48 PM
TerryLee TerryLee is offline
I'm new here so Hello everyone. Great Reading on this Website. I've been working on Onan's for a pretty good while now. I'm working on a Onan JC LNG/LPG with 34 hours on it from a school. It purrs. All the gas gasses is new to me. What I'm trying to do is make this 15Kw portable. My though are to use a 4 cylinder setup from a tow motor. I want to use a carb/mixer and vaporizer unit for the side ways stainless steel tanks. I'm not sure how to put this together safely ie flow pressure volume etc. Any help would be greatly appreciate.
Thank You
Model 15.0JC-5DR/18208AA
Serial G770251841
Volts 120/240
Old 07-21-2017, 01:53:49 PM
That's one nice paint job. How many hours did you put into the total job. Looks brand new.
Old 09-14-2018, 02:01:19 PM
csthompson12 csthompson12 is offline
I would be interested in more info on the flywheel grinding... I was about to do this on my CCK... Thanks
OEM Electronic Ignition for Onan AJ redrockx Onan Generators 24 05-06-2017 04:38:13 PM
My Electronic Ignition for Onan 4 CCK K D Redd Onan Generators 39 06-30-2012 11:42:40 PM
Onan Electronic Ignition Cruiser Onan Generators 3 10-18-2010 10:31:01 AM
Onan electronic Ignition conversion ? NF BF GHanners Onan Generators 2 09-19-2009 07:40:49 AM
Electronic ignition for 4kw BH-series Onan gkitf16 Onan Generators 5 03-15-2009 02:14:35 PM
