Field-Brundage, Racine Sattley and Sattley Engine Registry
this thread has 37 replies and has been viewed 2241 times
Old 01-26-2019, 11:49:34 AM
BakerCollector BakerCollector is offline
Default Re: Field-Brundage, Racine Sattley and Sattley Engine Registry
Does anyone know of an engine that was made that resembles the Type B United? Another suggestion was Bluffton built but I haven't seen one of those either to compare.
Dale Salmon
United Engine Registry & Website Caretaker
www.AUGERMO.com
Old 01-28-2019, 09:04:25 AM
Denis Rouleau's Avatar
Denis Rouleau Denis Rouleau is offline
I had not received any more Field-Brundage info to add to the registry in the last 2 months but this all changed yesterday when I was sent info on engines #2947 and #3433 which you can look up here:
http://buzzcoil.brinkster.net/Field%...e/page101.html
Anyone else have a Field-Brundage to add to the registry?
Thank you!
Denis Rouleau
Old 01-28-2019, 12:23:20 PM
Skip Landis Skip Landis is offline
Denis, here is a 3 hp that i have, #10233. I don't have pics. It is throttle governed, missing webster & bracket. I would sell it for $195 if anyone wants it. skip
Old 01-28-2019, 02:37:02 PM
Originally Posted by Skip Landis View Post
Denis, here is a 3 hp that i have, #10233. I don't have pics. skip
Did you get the serial number off of a name tag or from somewhere else on the engine? That serial number is close to the last number used on a Field-Brundage.
Denis Rouleau
Old 01-28-2019, 08:37:04 PM
Culy Culy is offline
Here is another one for your registry.
ID:	327388   Click image for larger version
ID:	327389   Click image for larger version
ID:	327390   Click image for larger version
The Following User Says Thank You to Culy For This Post:
  #36
Old 01-29-2019, 12:37:52 AM
It came from the tag
The Following User Says Thank You to Skip Landis For This Post:
  #37
Old 01-29-2019, 08:08:23 AM
I need to see a picture of the name tag for the registry. If you don't have one now, I'll settle for one later.
Thanks!
Denis Rouleau
---------- Post added at 08:08:23 AM ---------- Previous post was at 07:30:46 AM ----------
Your "Racine Sattley" is now in the registry here:
http://buzzcoil.brinkster.net/Field%...e/page104.html
Thank you!
Denis Rouleau
Old 02-05-2019, 06:58:36 PM
David Babcock David Babcock is offline
Smile Re: Field-Brundage, Racine Sattley and Sattley Engine Registry
Heres a photo of my "naked" field. Stripped paint, pins , bushings and decals. Serial# 8739. For the registry. Db.
ID:	327974   Click image for larger version
The Following User Says Thank You to David Babcock For This Post:
Feild & Brundage / Racine Sattley BobRR Antique Gas Engine Discussion 54 02-14-2019 08:35:29 AM
Sattley, Field Brundage what can you tell me? Will Batty Antique Gas Engine Discussion 9 01-30-2019 09:54:00 AM
Field Brundage, Racine Sattley, OR BOTH? greenmars2 Antique Engine Photos 4 04-29-2016 01:04:50 AM
1 1/2 hp Sattley (Field-Brundage) repops? Eric McKenna Antique Gas Engine Discussion 0 07-11-2015 07:06:05 PM
Indentifying a Field Brundage / Sattley Harry Antique Gas Engine Discussion 9 08-07-2008 02:17:36 PM
