Need to replace Mogul SS cam gear
this thread has 4 replies and has been viewed 440 times
Old 02-08-2019, 10:09:06 PM
Martin Reed Martin Reed is offline
Default Need to replace Mogul SS cam gear
I have an 8hp Mogul that is still in its original work clothes; was used to cut wood up until the early 90's. She is not as tight as when new and the cam shaft was getting very sloppy. I had a new cam gear made a couple of years ago thinking it would need to replacing, so finally decided it was time and removed the cam shaft assembly this past weekend. The cam gear is a little worn! If you look at the root of the teeth you can see where the mating crankshaft gear was wearing which means will probably have to replace the main bearings. I was expecting this to be a couple of hour job but it looks like I am in for a complete overhaul.
The last photo is when I purchased the engine several years ago, have since removed the buzz saw. This engine was originally sold to a farm in Ashland, VA. Sold at auction in the mid 60's, moved across the South Anna River and then purchased by me.
Martin
ID:	328196   Click image for larger version
ID:	328197   Click image for larger version
The Following 7 Users Say Thank You to Martin Reed For This Post:
Old 02-08-2019, 11:04:08 PM
Rob Charles Rob Charles is online now
Card Sponsor
Default Re: Need to replace Mogul SS cam gear
Looks like they got their monies worth outta that Mogul. Rob
Old 02-09-2019, 01:58:53 PM
JWithers JWithers is offline
I'm betting that made a bit of clunking noise. I've got a 12hp Mogul that clunks a bit with some rotational slop in the shaft. I should take it apart and make sure it's not as bad as yours.
Jeremy Withers
Old 02-09-2019, 02:10:21 PM
Chris Epping's Avatar
Chris Epping Chris Epping is offline
Images: 41
Yeah, that is a common Mogul problem, but that is worse than usual! You're lucky it never got to binding and broke the bearing housing off. How is the crank gear? Steel I assume?
Old 02-09-2019, 05:44:12 PM
what led me to looking into this first was I removed the governor case lid to inspect the weights. I have seen other Mogul engines with busted governor cases and that led me to inspect the inside of mine. The pins holding the weights are heavily worn with my suspicion being they typically don't get any lubrication. There is no provision for lubricating them unless you take the lid off.
I poured some oil all over the assembly and decided to rework them at a later date. I now suspect the broken/cracked governor cases were from the weight assembly pins wearing out and allowing them to strike the case.
If I owned a Mogul I would check your governor weights to make sure they are secure and throw some oil on them.
Chris,
the crank gear is steel and is in good shape.
Martin
The Following 3 Users Say Thank You to Martin Reed For This Post:
Farmall H, how hard to replace third gear? DanH Antique Farm Tractors 3 01-26-2012 09:45:52 AM
1 3/4 Mogul mag gear Keith Johnson Magnetos, Ignition Coils and Spark Plugs 5 06-10-2010 09:12:19 AM
Gear needed for 1hp Mogul RKing Antique Gas Engine Discussion 2 09-02-2008 12:31:17 AM
1hp Mogul intermediate gear Roo Antique Gas Engine Discussion 3 04-26-2007 12:45:44 PM
Mogul Gear Oiling? Dan Bogart Antique Engine Archives 1 05-27-2003 09:22:35 PM
