Go Back   SmokStak > SmokStak® Antique Engine Community > Antique Marine Engines and Outboard Motors
Antique Marine Engines and Outboard Motors Discussion on old marine engines, naptha, gas, oil or steam and vintage outboard motors.
Gray Marine Engine Identify Please
this thread has 13 replies and has been viewed 2167 times
Old 01-20-2018, 12:36:37 PM
Richard Durgee Richard Durgee is offline
Default Re: Gray Marine Engine Identify Please
External
Name:	Gray T 5.jpg
ID:	300917   Click image for larger version
Name:	Gray T 6.jpg
The Following User Says Thank You to Richard Durgee For This Post:
Old 01-20-2018, 01:55:49 PM
blacktinlizzie blacktinlizzie is offline
Yes that is the valve I was talking about mine is just a hole that is not threaded
I am thinking of making a plug machined to port water back to the water supply
Thank You for the photos Bill
---------- Post added at 12:55:49 PM ---------- Previous post was at 12:34:06 PM ----------
That engine is the same as mine
Do you have photos of the other side
Again Mine has fittings one at the crankcase and one on side of cylinder behind timer
Engine came with double drip oiler which mounted with two machine screws above the timer Thank You again for your help Bill
Old 04-05-2018, 12:20:04 PM
Robt.'s Avatar
Robt. Robt. is offline
Photos touched up. This free program is excellent for photo editing. Or if you just want to use the MS Paint that comes will windows: https://r.search.yahoo.com/_ylt=Awr9...O7bnI3MpR6dtU-
I have the same engine, very nice quality unit with a counterbalanced crankshaft. You're missing the cylinder head cap obviously, but if you want dimensions I can get you those. A metal spinner could make you up one out of brass or copper I guess. The originals were just steel, which wasn't the greatest choice for salt water, though it dents less easily.
There was a cast iron cover over the water pump gears originally. Can get you dimensions of that too if you want.
You've got the engine tag or did someone steal that?
Lots more photos and info on these over at www.oldmarineengine.com Just do a search and you'll see.
ID:	307420   Click image for larger version
ID:	307421   Click image for larger version
ID:	307422   Click image for larger version
The Following User Says Thank You to Robt. For This Post:
Old 01-26-2019, 05:43:02 PM
177tony 177tony is offline
I have a two cylinder, two cycle Gray Motor Company marine engine. Serial number in evidence is 112R9695.. Any information about this engine will be appreciated. Thanks
Gray 4-stroke 5 hp. marine engine hms50 Antique Marine Engines and Outboard Motors 6 10-10-2016 09:49:14 AM
Gray marine engine GlenK Antique Gas Engine Discussion 7 08-26-2015 07:02:25 PM
Gray Model S marine engine Bob Johnson Antique Marine Engines and Outboard Motors 1 09-15-2013 10:27:55 AM
10/12 H.P. Gray Marine Engine found Greg-N-CA Antique Marine Engines and Outboard Motors 9 03-20-2011 07:24:10 PM
6-91 # B?263 Gray Marine Engine agsem Antique Marine Engines and Outboard Motors 7 10-09-2007 12:29:45 PM
