Go Back   SmokStak > SmokStak® Antique Engine Community > Antique Marine Engines and Outboard Motors
Antique Marine Engines and Outboard Motors Discussion on old marine engines, naptha, gas, oil or steam and vintage outboard motors.
1957 Evinrude BigTwin 35 Model 25028 has oily output
this thread has 4 replies and has been viewed 438 times
Old 08-17-2018, 05:08:11 PM
creamsicle creamsicle is offline
Default 1957 Evinrude BigTwin 35 Model 25028 has oily output
I just joined Smokstak because it helped me find out more about my "new" '57 Evinrude Model 25028 (like that it needs 24:1) which I recently bought to replace my '73 Johnson 65hp that developed a quarter-sized hole in its crankcase and will now run only if I hit the primer bulb every 30 seconds (too inconvenient for watersports). I also know very little about outboards and hope to learn a lot from this community.
So here's my introductory question: WHAT DOES IT MEAN WHEN A RUNNING ENGINE DEPOSITS A LOT OF OILY/GREASY BROWN YUCK INTO A WATER TEST BARREL? My Evinrude was supposedly winterized 3 years ago (not run since), so I'm hoping this oily stuff is just fogging oil residue and/or normal exhaust products. On the other hand, this yuck is draining out out of the rear port below the cowling: is this more indicative of a serious lower unit issue? (Either way, I don't relish the idea of my motor putting this yuck into the pristine waters of my favorite N. Idaho fishing lakes.) Thanks for any answers you guys & gals can provide!
Name:	1957 Evinrude BigTwin35 oily water.jpg
ID:	316467   Click image for larger version
Name:	1957 Evinrude BigTwin35 oily water CLOSEUP.jpg
Old 08-17-2018, 09:13:41 PM
Default Re: 1957 Evinrude BigTwin 35 Model 25028 has oily output
I'm not a boat guy but is the lower unit leaking it's oil out? If not, run it and see how it goes.
Old 08-17-2018, 11:09:15 PM
do a compression test,mite need rings and pistons,check the head gasket for leaks from water jacket,and old outboards impellers wil get crispy and take a crap,its there good luck...
---------- Post added at 11:09:15 PM ---------- Previous post was at 11:04:45 PM ----------
remember its coming out your exhaust,its a 2 stroke and you wiil get some oil out but not that much or nasty,make sure u check the water jacket
Old 08-18-2018, 12:06:45 PM
Heller D. Davis Heller D. Davis is offline
What is the fuel to oil ratio you have in the tank? Could be too much two cycle oil also.
Old 08-18-2018, 12:40:35 PM
Exclamation Re: 1957 Evinrude BigTwin 35 Model 25028 has oily output
Several comments for you. 1) check the lube in the lower end. it should look like a light grease or heavy oil, not milky and white. If it (the lube) is clean, you are good. if milky, you need to replace seals and change the lube to a fresh batch. 2) As for oil in the exhaust - 24:1 still is a bunch of oil compared to modern engines which use 50:1 or leaner mixes. You will get an oil sheen from your engine. Remember, running in a barrel concentrates the exhaust oil. In a lake or pond, there won't be much at all. if the engine was charged with oil before storage (fogged), then that oil will also be thrown out the exhaust until it is totally burned off. 3) what oil are you using? If SAE 30 NON Detergent, you might switch to a modern marine 2 stroke oil. Your engine should be able to digest it. If already using modern OIL, you should be OK. 4) There should be a discharge port for cooling water on your engine. When running, make sure water discharge is steady and full stream out the port. If the discharge is choppy or weak, then the rubber pump impellor needs to be replaced. A good marine shop should be able to get parts like seals and the impellor if needed
What ventilated the case on your other engine? if just corrosion, it can be sealed with a patch and some epoxy, like JB Weld. if the cause was mechanical (thrown rod), then you are SOL
Evinrude Model 4383 Lightfour Carburetor Jim M. The Junque Drawer 11 10-30-2012 05:12:25 AM
Evinrude Elto what model do i have? Antiquebriggsguy Antique Marine Engines and Outboard Motors 3 02-26-2012 11:35:45 PM
New Toy, Evinrude 1940 Model 4357 3hp ScooterBob Antique Marine Engines and Outboard Motors 3 08-07-2011 11:09:45 PM
1957 Evinrude grub54891 Antique Marine Engines and Outboard Motors 7 07-30-2008 08:06:37 AM
1957 Farmall alternator output Jordan Antique Farm Tractors 7 12-18-2007 09:22:44 PM
