McCormick Deering / IHC old iron
this thread has 11 replies and has been viewed 1123 times
Old 02-04-2019, 12:49:30 AM
Junkologist's Avatar
Images: 160
Default Re: McCormick Deering / IHC old iron
Lots of guys run white has or naphtha in their engines since it wonít cause problems from sitting, but you can run regular pump gas too with no problems, but donít leave the engine sit with gas in the tank. Youíll have problems if thereís ethanol in the gas. You mentioned being involved with aircraft repair. If you have access to avgas, thatís also a good option for fuel that wonít cause problems from sitting, which you are probably already aware of.
Hereís a video of my gasoline only IHC M. Yours should be the same.
Mike
SmokStak member #146
Old 02-04-2019, 03:42:17 PM
I would use high test fuel, if available. It has less alky then regular. E-10 id hygroscopic. That means it draws water out of the air (humidity). This in turn causes rusting in the tank, and phase separation which will ruin your fuel pump. If you plan to let the engine rest more than a week, I would drain all gas from the tank, and run the engine dry - out of fuel. Dead gas can cause all kinds of problems.
What Would this old iron Be worth? McCormick-Deering W30 Diamonddriller14 Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 4 03-28-2015 10:59:55 PM
1 1/2 McCormick Deering M MarkBillesbach Antique Gas Engine Discussion 32 09-19-2012 02:11:01 PM
McCormick Deering 10-20 SDP Antique Farm Tractors 29 02-25-2012 03:51:28 AM
McCormick-Deering 10 HP M Tim Smith Antique Gas Engine Discussion 13 12-11-2011 10:14:20 AM
McCormick Deering 1.5 hp value? BobM Antique Gas Engine Discussion 5 08-07-2009 05:15:19 PM
