Flat Drive Belts Need Repair or Replace
this thread has 14 replies and has been viewed 1026 times
Old 02-03-2019, 09:47:48 PM
Brianne163 Brianne163 is offline
Default Re: Flat Drive Belts Need Repair or Replace
Original belt shortened 2" and laced up. Yet to try.
For practice I laced up the fire hose anyway.
I will let you all know how they go.
Thanks for all the help
Old 02-03-2019, 09:51:39 PM
Pic of lacing FYI.
The Following User Says Thank You to Brianne163 For This Post:
Old 02-03-2019, 10:07:48 PM
Very good job.
Old 02-04-2019, 08:04:18 AM
Inter Bloke Inter Bloke is offline
Pic of lacing FYI.
That is almost exactly how they used to relace the main drive belts on old ground drive harvesters as well as other equipment back in the day, if it's done correctly it should be fine !
Old 02-04-2019, 03:50:49 PM
Norm W Norm W is offline
Oldstuff's statement about the fire hose, "A hose won't work if used as is. Think of it as two belts one over the other. The inside layer runs on the pulleys while the outer runs on the top of the other one. They will want to rotate at different rates due to the diameter differences and will fight each other consuming a ton of horsepower" left me with a question. What would happen if the hose was laced as a Mobius Loop so that the outside and inside were the same side?
Flat Belts John Hanobik Steam Stationary Engines, Traction Engines, Steam Boats 1 12-13-2014 09:23:42 PM
Flat Belts boz Scale Model Engineering 4 10-11-2013 07:53:08 AM
Where to buy flat drive belts + Pulleys Bigjoedo Antique Gas Engine Discussion 9 10-16-2010 12:13:16 AM
Flat Belts Scott Kocher Antique Gas Engine Discussion 1 08-25-2010 08:37:08 AM
Making flat belts from conveyer belts Ihorse Antique Gas Engine Discussion 7 12-03-2005 11:01:16 PM
