Fairbanks Morse 3hp Plugocillator Magneto Help
this thread has 10 replies and has been viewed 551 times
Old 01-31-2019, 11:01:01 AM
Kanonier74 Kanonier74 is offline
Question Fairbanks Morse 3hp Plugocillator Magneto Help
Hello everyone, I'm new to this group and very happy to have found this forum. Im near finished with a complete restoration of my 1918 Fairbanks morse 3hp z type b plugocillator. It came with the original sumpter magneto, believe it's a style 14. I opened it up, no rust inside looks good. Coil has continuity, magnets appear weak. I'd like to get it working again but don't know how to properly test it. It's a California engine, so parts are not very rusty. Does anyone have advice to to repair it or has a referral.?
Next question is, would it be easier to connect a spark coil instead, and how is this done, where to get these parts from? Thank you, any help is appreciated. Pete.
Old 01-31-2019, 11:04:44 PM
jackjohnhunt jackjohnhunt is offline
Default Re: Fairbanks Morse 3hp Plugocillator Magneto Help
It's pretty simple to make it run with a coil and battery. I think I have a diagram in my photos. If I do I will attach a copy.
Old 01-31-2019, 11:13:43 PM
Here is the diagram, hope this helps. I just made this system for a Hercules 1 1/2 hp today.
Old 01-31-2019, 11:24:23 PM
Junkologist's Avatar
Images: 160
Try to find someone local who can charge your magnets. If you ask around at shows, someone will know somebody with a charger. Sounds like the rest of your magneto is ok and with the magnets up to snuff, it should be good and hot.
Have you tried tripping the magneto/ignitor assembly to see if there’s spark?
---------- Post added at 10:24:23 PM ---------- Previous post was at 10:19:29 PM ----------
This won’t work on Kanonier74’s engine. A plugoscillator is a low tension ignitor. There’s no spark plug.
Mike
SmokStak member #146
Old 02-01-2019, 01:32:06 AM
cobbadog cobbadog is offline
Try your magneto first to see if it is 'hot'. Only operate it in a way that it will make a spark to ground via jumpimg a small gap or spark plug. Best not to operate the magneto with the HT lead just hanging in mid air this damages the magneto.
As for recharging, Junkologist made a great suggestion and then you will meet someone who can help you out and become a great mate. Failing that there is a sponsors page listed in the dark blue line at the top of the page on the very right hand end. Find one near you and make contact with them.
For me I like to see a magneto on an engine that came with one but it is always your choice as it is your toy. Good luck with it and let us know how you get on.
Old 02-01-2019, 01:39:02 AM
jbo.aermotor jbo.aermotor is offline
You need too get Gab too Recharge you Mag! Ben
Old 02-01-2019, 09:08:32 AM
The plugoscillator is a low tension mag. It produces only a couple of volts and will not jump a gap. A low tension system creates a spark only when the ignitor points snap open. There is no spark plug involved. There is no high tension to destroy a coil.
Old 02-01-2019, 05:34:21 PM
thanks for all the advice friends.
yes its a low tension sumpter #14, that came original with the engine. the shaft was rusted and seized, after oiling it and carefully completely disassembling it, everything moves with ease now. magnets do appear weak but the coils and other parts inside look amazingly very well. I think it works, just don't know exactly how to test it. I have a multimeter (DVOM), if I mount it on the ignitor bracket, trip it , I don't see spark when the points are open, this im doing on the bench and im not sure if this is a valid test. Ill attach pictures at a later time. thanks everyone .
---------- Post added at 04:34:21 PM ---------- Previous post was at 04:32:08 PM ----------
can you get me Gabes # , thx Ben
Old 02-05-2019, 10:16:36 AM
I took the mag completely apart again, turns out the magnets were backwards, corrected this, feel some little resistance now when turning the mag but only 1.8v coming out. I have it apart now down to the bare coil. I measure between the 2 wire ends and have an open circuit. I suspect there is an open in the winding somewhere. Does anyone have further advise or a resource? Thank you.
Old 02-05-2019, 10:25:24 AM
I added some pictures of the coil. I have an open circuit
ID:	327942   Click image for larger version
R magneto for fairbanks morse 2hp Z gt4 Magnetos, Ignition Coils and Spark Plugs 2 09-15-2015 04:11:06 PM
1.5 Hp Fairbanks Plugocillator governor bracket problem BigGoomba Antique Gas Engine Discussion 0 07-23-2014 01:06:00 PM
Fairbanks Morse 118 magneto joe n Oil Field Engines & Related Equipment 5 11-14-2011 08:29:13 AM
Magneto for a Fairbanks Morse 6HP Z J.Bubba Lee Antique Gas Engine Discussion 10 08-27-2011 08:23:27 PM
Help with a Fairbanks Z and a Sumter plugocillator? bstratton Antique Gas Engine Discussion 11 01-18-2009 06:13:38 PM
