Fairbanks Morse, 1.5 horse, throttle governed rebuild
this thread has 20 replies and has been viewed 873 times
Old 02-11-2019, 01:37:43 AM
Jeff Taylor Jeff Taylor is offline
Default Re: Fairbanks Morse, 1.5 horse, throttle governed rebuild
You may not need to sleeve the cylinder. I have seen many engines run just fine with pitted cylinders. I have some as well. I would suggest repairing the valve first and then seeing if it has compression. If t has compression it will probably run. How much running will the owner actually do with this engine? If it will only run once or twice a year it wont need to be perfect.
You also may not need to sink the valve seat 1/8". Take your time, do a little and check the seat as you go. You can buy new valves and sometimes you can use automotive valves.
Heads can be brazed as well. I have a 1927 Z with a brazed head.
Old 02-11-2019, 07:07:09 PM
davebrode davebrode is offline
Hi Jeff,
Thanks for your reply.
The original head is really rough, The bridge between the bowl and the port to the ignitor was rusted away and paper thin, as in 1/16" It turned to dust when I tried to grind a new seat. I bought a decent head that has been frozen and broken on the bottom, but repaired with brass. Decent repair. Plus, being on the bottom, it will not be nearly as noticeable.
When I saw how thick the wall between the valve bowl and the port to the ignitor I was really surprised. I ground the seats, and I didn't have to sink the exh much at all, the intake took only a touch. I have been looking at automotive valves with chromed stems. The stems look rough as a cobb on the stock type replacement valves that I've seen.
The cylinder wall has a section with pits 1/8" deep! Many many others 1/16' or so. Sleeving isn't a big deal.
I'll post pictures in a day or two.
Thanks again.
Dave
Old 02-16-2019, 12:12:51 AM
Cylinder wall.
ID:	328750   Click image for larger version
Old 02-16-2019, 12:20:08 AM
Sorry about the double
Old 02-17-2019, 05:54:39 PM
Cleaned up, ready for sleeve.
Name:	ZB block.jpg
ID:	328846   Click image for larger version
ID:	328847   Click image for larger version
ID:	328848   Click image for larger version
Name:	ZB crankcasemains.jpg
Old 02-17-2019, 05:55:41 PM
crank will polish up nicely
Old 02-17-2019, 05:56:43 PM
xxxxxxxxxcx
Name:	ZB crank.jpg
Old 02-17-2019, 06:13:52 PM
I will get pics of carb, and many other small parts, already cleaned and painted [ford dark green used on T engines, it I hope that it's close]. They are at work.
Old 02-17-2019, 06:17:46 PM
I meant to put these in the last post. Sorry.
ID:	328859   Click image for larger version
ID:	328860   Click image for larger version
ID:	328861   Click image for larger version
Old 02-17-2019, 06:19:52 PM
xxxxxxxxxx
ID:	328863   Click image for larger version
ID:	328864   Click image for larger version
ID:	328865   Click image for larger version
Fairbanks Morse Z Throttle Governed or Hit and Miss? FibberMcgee Antique Gas Engine Discussion 8 05-15-2018 02:15:11 PM
Fairbanks Morse 3 hp Throttle Governed Z Gas Tank Day Radebaugh Antique Gas Engine Discussion 8 06-07-2017 12:29:36 PM
Fairbanks Morse 3 HP Throttle Governed Z Jumping Around Day Radebaugh Antique Gas Engine Discussion 21 10-14-2016 08:28:00 AM
Fairbanks Morse 3hp throttle governed engine... 1911LY Antique Gas Engine Discussion 8 07-24-2015 09:34:32 PM
1929 Fairbanks Morse 2 HP Dishpan Throttle Governed Dave L M Antique Gas Engine Discussion 5 01-11-2012 01:05:09 AM
