Dempster 2 1/2 HP Class 2H
this thread has 12 replies and has been viewed 570 times
Old 02-10-2019, 09:22:41 AM
Target Driller Target Driller is offline
Thumbs up Re: Dempster 2 1/2 HP Class 2H
That's a sweet engine Joel
I like the embossed name on the side face of the water hopper.
The Following User Says Thank You to Target Driller For This Post:
Old 02-10-2019, 10:56:10 AM
Matt Weismiller Matt Weismiller is offline
Default Re: Dempster 2 1/2 HP Class 2H
Looks good Joel.
The Following User Says Thank You to Matt Weismiller For This Post:
Old 02-10-2019, 02:09:34 PM
Joel Mosley's Avatar
Joel Mosley Joel Mosley is online now
Images: 26
Originally Posted by DavidRaines View Post
When I got mine all I could find was gray paint.???
David,
I believe that all Dempster's were green, but this is based on observations and catalog images.
They used a very thick heavy paint. The ones I've seen that have set outside for a long time have faded out and lost the majority if not all of their pigment. The original engines with lots of Grease are definitely a dark green.
Here is an update below after looking at the attached pictures.
Attached are a couple of pictures of original engines that were very greasy. They were cleaned carefully revealing the original paint. The first one is just a picture of the nice dark green paint. The second one shows the side of the hopper. If you look closely there's green paint on top and then a darker gray filler primer material underneath it where the top coat has peeled or chipped off. I think what happens is that the less durable green finish paint wears off in the sun and leaves the gray filler primer which fades over time.
ID:	328350   Click image for larger version
The Following 2 Users Say Thank You to Joel Mosley For This Post:
15 Hp Dempster Matt Montague Antique Gas Engine Discussion 0 01-14-2017 11:36:33 PM
Dempster Help! 1 1/2hp J.R.Smith Antique Gas Engine Discussion 8 08-30-2016 10:32:21 PM
15 H.P. Dempster David Hoover Antique Gas Engine Discussion 0 02-02-2012 06:28:25 PM
Dempster Ind. MarkBillesbach Antique Gas Engine Discussion 5 09-04-2010 07:10:22 PM
Dempster? MIKE Antique Engine Archives 1 12-15-1999 11:32:26 PM
