Go Back   SmokStak > SmokStak® Old Iron and Tractor Community > Horse Drawn Equipment
Horse Drawn Equipment Old iron designed for the purpose of hitching up to a horse or a team. This old iron machinery may be used or demonstrated while hooked to an old iron tractor too.
Malleable Iron or Cast Iron
this thread has 10 replies and has been viewed 2030 times
Old 01-08-2017, 09:50:36 PM
wagonbuilder joe wagonbuilder joe is offline
Default Malleable Iron or Cast Iron
I am looking for wagon steps for horse drawn wagons. Ebay has many but most are listed as cast iron steps. My book of historic horse drawn wagon hardware shows steps of steel and malleable iron. No cast iron. I suspect the "antique" wagon steps listed on Ebay are incorrectly labeled as cast iron and are probably malleable iron or steel but I am not sure. I don't know how to tell the difference in a photo of malleable or cast iron. Were any historic wagon steps make of cast iron? I think they would be too brittle to support a sudden thrust of a heavy person jumping up or down on a step. Any thoughts?
Old 01-09-2017, 01:01:13 AM
LCJudge LCJudge is offline
Default Re: Malleable iron or cast iron
I know nothing at all about antique wagons....but, I would have to agree that the steps you see advertised on ebay and other sites, if they are truly vintage steps, are made of malleable iron. CI would snap too easily, especially if someone weighing 250 plus jumped on them at 10 degree temps.....Its virtually impossible to tell the difference just by eye or a photo if something is Cast Iron or Malleable Iron.
Tommy Turner
The Following User Says Thank You to LCJudge For This Post:
Old 01-09-2017, 01:16:04 AM
Mike Rock Mike Rock is offline
Well, the only clue is that very small sections can be cast in malleable iron, which is white iron as cast. Gray iron, commonly known as 'cast iron', is generally somewhat thicker and will not flow as well as the white iron. Fluidity differences are about all the visible clues you will have.
The Following User Says Thank You to Mike Rock For This Post:
Old 01-09-2017, 05:07:25 PM
tdmidget tdmidget is offline
There is a slight difference in the spark. Need to do it in a dark room and have samples of cast, at least, to compare to There's not a lot of difference but the malleable spark is slightly longer with less bursts.
The Following User Says Thank You to tdmidget For This Post:
Old 04-09-2017, 07:09:23 PM
cchopper cchopper is offline
I can not help on knowing the difference between metals just by looking at them.
But I am a step collector of horse drawn vehicles. I mainly look for steps with a name on them. So I'm watching ebay very frequently. Many of the sellers have no idea what the are selling. I often see items being sold as steps were never steps. The biggest joke I see often is cattle watering cups with the actuator the cow would push down on to open the valve and allow water in the cup, these are many times sold as buggy steps!!!
I don't actually have any extra wagon steps right now. But feel free to look at buggysteps.com to see what I do have.
The Following 3 Users Say Thank You to cchopper For This Post:
Old 01-08-2018, 10:23:01 PM
Avery22x36 Avery22x36 is offline
Studebaker 3 leg steps often break right in the bend before the tread plate, I work on a lot of buggies, I have seen many broken steps and many brazed and nickel welded as well. I don't know what they are made but if I weighed 300lbs I would sure think twice before I stepped up on one.
Old 01-09-2018, 11:51:13 AM
Bob Willman Bob Willman is offline
Default Re: Malleable Iron or Cast Iron
I would think that forged ones should be superior and stronger. Also more expensive.
Bob
WB8NQW
Old 01-09-2018, 12:15:19 PM
How about a link to real cast iron steps? If Doug Engels says they are cast iron, they are cast iron. http://engelscoachshop.com
Doc
This line left intentionally blank...
Old 01-09-2018, 07:24:47 PM
Scotty 2 Scotty 2 is offline
Different colour too. Yellow versus orange.
Old 01-09-2018, 09:55:05 PM
I am pretty sure Doug is right, when you break one the iron looks like a pot bellied stove casting that is broke, they are not very strong. You see steel steps on heavy wagons and stage coaches, things like that but they are not very attractive as they do not have logos or designs casted into them.
Broken Sub Base: Mold, Cast, Cast Iron Weld DaveTexas Antique Gas Engine Discussion 24 03-17-2011 12:00:46 AM
Stickney Cast Iron Seat Do You Need One Cast? Marshal Reysen Antique Gas Engine Discussion 5 04-08-2010 01:22:44 PM
Stickney Cast Iron Seat Cast? Craig A Antique Gas Engine Discussion 0 01-22-2010 09:01:44 PM
Need help-cast iron Dennis K. Nash Antique Gas Engine Discussion 9 11-22-2009 02:58:16 PM
To make new valves - cast steel / cast iron Edwin Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 12 05-02-2009 12:53:18 AM
