Go Back   SmokStak > SmokStak® Antique Engine Community > Multi-Cylinder Stationary Engines and Power Units
Multi-Cylinder Stationary Engines and Power Units Waukesha, Buda, Climax, LeRoi and others.
Buda 6 cyl diesel genset
this thread has 2 replies and has been viewed 1911 times
Old 01-27-2012, 12:27:12 AM
carnuck carnuck is offline
Default Buda 6 cyl diesel genset
We're pulling 2 of these from a yacht that's getting refurbed. I thought I might put one in my '71 IH 5 ton 18' flatbed dump (it already has a 5 speed Clark with a Brownie over/under box and 3 speed Eaton axle)
I was told that I'd have to change the cam and some externals to make it work. The truck currently has a thirsty 345 (2.5 mpg) with only 17,000 miles on it (farm truck) and I plan to do the swap meet circuit with it. I have an LPG powered on board air compressor (I replaced the 11hp Wisconsin I sold on here with an 18 HP Briggs commercial) and it won't move around a lot. I've considered just making the 345 LPG, but I don't know how well it would handle it.
I figure it'll be enough to move cargo containers and the tractor as well as building materials. It would cost at least $10k to buy a truck 1/2 as strong, but I'm getting long in the tooth and it's tougher to work on stuff nowadays.
Old 01-27-2012, 01:29:13 AM
Default Re: Buda 6 cyl diesel genset
The people over at IHC.org can probably advise on the cost of converting to LPG, the usual mileage and other dos and donts in a conversion of your engine...
Your advisors are probably right about the cam; gensets are sometimes set up for a particular RPM range much narrower than a truck engine; on the other hand you're not short of gear shifts to keep RPMs fairly constant, but it might wear out your leg shifting...
Try John Paulsen in Olympia (johnpaulsen@comcast.net) or Jim Couzens (phonetic) at Buda engine in Shreveport (budaengine.com) for a power curve for your engine and/or if different cams are available, etc. Good luck.
Old 01-27-2012, 03:00:45 AM
Thanks. I considered putting the BG241 I have from my '68 Travelall in, but I doubt the economy would rise much. It only gets 10 mpg now. The IH 304 I have (from a rusted out 66 Travelall) will be going in the '68 anyways. I've been trying to find a O/D from a Rambler for the Borg Warner M8 auto so 55 mph won't be the top speed anymore. (I already have better brakes for it)
Buda Engine (Buda, Illinois) TomAnderson Antique Gas Engine Discussion 5 02-15-2015 09:57:54 PM
Buda/Century genset Jim Rankin Generators & Electric Motors General Discussion 24 08-30-2013 08:23:52 AM
Buda Diesel Generator davidradio Vintage Diesel and Oil Engines 1 07-03-2011 10:48:19 PM
3-71 GM Diesel GenSet Roger Boardman Generators & Electric Motors General Discussion 13 07-11-2008 09:48:43 PM
Small Buda diesel with Kato-Light genset? Robt. Generators & Electric Motors General Discussion 1 04-09-2006 12:05:38 PM
