Go Back   SmokStak > SmokStak® Support and Information > Smokstak Forums Meet and Greet
Smokstak Forums Meet and Greet Welcoming Smokstakers New and Old, a place to say a bit about yourself and post a photo if you're really brave. If you have a technical question, please post it on one of our other boards.
Onan 4K Microquite KY series generator runs, stops, over speeds etc.
this thread has 0 replies and has been viewed 748 times
Old 01-07-2017, 01:07:42 PM
WHallTN WHallTN is offline
Default Onan 4K Microquite KY series generator runs, stops, over speeds etc.
For all the Onan gurues out there here's another mysterious quirk.
Generator sat idle for a year or so-wouldn't start. Drained main tank, purged lines with fresh fuel, got it to start but died. Removed carb, cleaned-ran rough, but ran, cleaned carb again. Replaced fuel filer and pump. seemed to run Ok for 5-30 minutes at a time then died. Wouldn't restart without manually manipulating choke-black smoke coming out of exhaust. Had to wait until it cooled completely before it started again. Ambient temp in the 50's. Again, would run for 5-20 minutes and then started to overspeed and shut down (code 14-overspeed condition sensed).
Backed off governor. Ran fine, put microwave and AC load on-ran great. Ran again later, microwave and AC load and when microwave timed out unit oversped again. Wouldn't restart until after cooling.
Ran it yesterday (temps below freezing) ran for 40 minutes until I shut it down.
I've read a ton of posts about this generator and am left with three things. First, fuel enrichment jet still not cleaned (although will sometimes run perfect for among period of time wth load/no load. Secondly, bad control panel affecting voltage regulator (although I get 125 volts consistently. Third, carberator itself is jacked up.
Troubleshooting:
-oil level checked and good
- fresh 100% gas with fuel treatment added
-voltage checked at AC outlet good-125 volts
-carb cleaned-three times
-fuel selonoind cleaned and works
-all wires checked for clean connection and grounded
-hooked up an external fuel cell to bypass entire fuel supply
While my intention is to run an external generator set (Honda EU1000 and EU 2000 parralled to provide longer running AC requirements) I'd still like the internal genset to work.
Only thing I can see changing is a new carb and/or control board. But that's not cheap.
Thoughts??
Onan Bfa runs for 30 sec then stops dave2500 Onan Generators 6 02-03-2015 06:39:04 PM
Onan 4KY F series generator only runs if I hold the choke open bjhamlyn Onan Generators 12 12-23-2014 05:18:58 PM
Onan BGE Runs then Stops Snprdog Onan Generators 7 03-07-2011 05:16:24 PM
Onan Microquite 4000 smoking tipelc Onan Generators 2 02-17-2010 09:17:09 AM
Onan Microlite 4000 runs then stops sparkymarc Onan Generators 8 07-16-2009 10:10:15 PM
