Holley Tractor Carburetor Needle Sticking
this thread has 4 replies and has been viewed 559 times
Old 10-14-2018, 11:22:15 AM
Tracy T Tracy T is offline
Question Holley Tractor Carburetor Needle Sticking
just as the title says, needle sticking in seat. seat is non servicable it is part of the carburetor. carburetor has been cleaned with a kit installed and runs fine until the needle sticks and starves it for fuel. no provision for a clip to attach it to float either. i think the viton tip is the problem. think a solid brass needle would cure it?
Old 10-14-2018, 11:15:31 PM
ulgydog56's Avatar
Default Re: holley tractor carburetor need sticking
roll the needle on glass and make sure its not bent
Old 10-15-2018, 08:24:46 AM
its not round so it wont roll.
Old 10-15-2018, 11:16:27 PM
ulgydog56's Avatar
Default Re: Holley Tractor Carburetor Needle Sticking
yes its tapperd but you should be able to tell thou if you roll it
Old 10-25-2018, 11:25:26 AM
John Hamilton's Avatar
John Hamilton John Hamilton is offline
Have the same problem with my 1930 Packard. It started when they began putting alcohol in the gas. We have E10. If it sits at all with gas in the carb it sticks and has to be taken apart.
I use the Stabil for motorboats which makes the gas usable but the needle still sticks and carb cleaner won't free it. The carb is a Stromberg SF-3, not original but a much better carb.
Holley Brass "All Fuel" Carburetor Jason Dahm Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 3 12-07-2013 06:35:19 PM
Water Injection for Carburetor (IHC Two Needle Type) pdatte Antique Gas Engine Discussion 3 04-15-2012 09:48:06 PM
Three needle carburetor Christian Berlin Antique Gas Engine Discussion 6 11-02-2008 09:20:52 AM
Fairbanks/Morse Carburetor Needle Valve triplepass Antique Gas Engine Discussion 4 02-19-2008 10:15:39 AM
What to do...what to do... carburetor needle Sky Small Air Cooled Gasoline Engines 8 12-22-2007 01:58:16 AM
