Wisconsin Engines
Wisconsin AEH, Unusual
this thread has 9 replies and has been viewed 636 times
Old 01-16-2019, 02:54:57 PM
Larry K Larry K is offline
Default Wisconsin AEH, Unusual
I have an unusual AEH which has a starter and a ring gear. It also has a belt driven generator. Would this be a military application or something else?
ID:	326455   Click image for larger version
The Following User Says Thank You to Larry K For This Post:
Old 01-16-2019, 05:50:08 PM
K-Tron K-Tron is offline
Default Re: Wisconsin AEH, Unusual
It looks like a normal civilian model AEH with all of the bells and whistles to me. I would like to see some more pictures of the radio shielded ignition. It looks like someone got creative and used a radio shielded wire and plug cover from a Briggs & Stratton. To my knowledge Wisconsin never setup an engine with a sparkplug cover. The military engines had aviation style plugs with real radio shielding down to the special Fairbanks Morse magnetos. It is hard to say what your engine could have powered. What does the end of the crankshaft look like. Is that section on the end tapered and threaded?
Old 01-16-2019, 08:42:38 PM
The crankshaft is straight. The end is 3/4 inch and then the section closes to the engine is 1 inch. Thanks.
Old 01-17-2019, 12:40:18 AM
ulgydog56's Avatar
nice, I had a 10 hp Wisconsin with starter hydo pump it was on a Friday cultivating tractor should have never sold that tractor...
Old 01-18-2019, 05:55:43 PM
Junkologist's Avatar
Images: 160
Hereís an AK that I have with a starter and generator. First one Iíve seen like it. No idea what the original application was.
ID:	326588   Click image for larger version
SmokStak member #146
Old 01-18-2019, 07:04:44 PM
Mike, Is that the engine I sent you the craigslist link for in central Ohio? It did not look like it had an outboard ring gear from the pictures in the listing. That is a great find. I do not know exactly what that engine came off of, but may have been a power buggy with electric start. That engine must have great compression, or a lot of hours on it to wear the starter gear like that.
Old 01-19-2019, 05:33:53 PM
Doug Tallman Doug Tallman is offline
From what I've seen, if the engine was factory equipped with the starter and gen that they also used a distributor and coil instead of the mag.
Old 01-19-2019, 06:02:26 PM
Images: 160
This is the engine from that link. I’ll have to turn it over and see if the bad teeth on the ring gear coincides with the compression stroke. The rest of the engine is in beautiful shape.j
Old 01-21-2019, 10:35:10 PM
Zira Zira is offline
I have seen engines with starters connected by belt to pulley's and magneto ignitions, but not many. I don't recall seeing an engine with a starter-generator that had a magneto ignition.
I have also seen engines with a ring gear and starter that had magneto ignitions, mostly the later S-series engines.
Someone with the spec-list microfiche & a lot of time on their hands could probably tell us for sure.
Old 01-22-2019, 12:11:02 AM
gdstew gdstew is online now
"Someone with the spec-list microfiche & a lot of time on their hands could probably tell us for sure."
Just so happens I might be able to handle that, but first, I need the spec number!
Actually been pretty busy in my "retirement" years
The Following User Says Thank You to gdstew For This Post:
Unusual Mower Zen Garden Tractors / Mowers / Scooters 13 02-16-2015 07:59:08 PM
Unusual Oil Can. What was it used for? Oilpullman Farm + Industrial Antiques and Collectibles 8 10-20-2010 12:34:00 PM
Unusual B&S? Ralph Leonard Small Air Cooled Gasoline Engines 3 10-14-2004 08:06:00 PM
