Wisconsin Engines
could someone tell me if this is an early Wisconsin engine
this thread has 11 replies and has been viewed 715 times
Old 03-23-2019, 05:09:40 PM
Eric McKenna Eric McKenna is offline
Default could someone tell me if this is an early Wisconsin engine
thinking its an early version, let me know your thoughts....good spark awesome compression
ID:	331205   Click image for larger version
ID:	331206   Click image for larger version
ID:	331207   Click image for larger version
The Following 4 Users Say Thank You to Eric McKenna For This Post:
Old 03-23-2019, 05:43:21 PM
Heins Heins is offline
Default Re: could someone tell me ifthis is an early wisconsin engine
It says Wisconsin so I think it is.
Old 03-23-2019, 05:55:52 PM
K-Tron K-Tron is offline
That is a fantastic find! Early air vane governed AG. I wish I could find a couple old engines like that to add to my lineup of Wisconsin engines.
Old 03-23-2019, 08:13:54 PM
Junkologist's Avatar
Images: 160
Nice find! January 1938 build.
SmokStak member #146
Old 03-23-2019, 08:51:33 PM
Lonnie Grissom Lonnie Grissom is offline
I have one that is just like yours. It powered a water pump. I hav not been able to find a crank. May have to make one. I bought mine just for the wico mag. I need mag for parts for mag for j d 3 hp ep. Later found another mag for parts. I got two projects to get running the Jd and Wisconsin.
The Following User Says Thank You to Lonnie Grissom For This Post:
Old 03-24-2019, 12:32:55 PM
Zira Zira is offline
Very nice. I have a couple AF's but no AG's. None as nice as that one.
Old 03-24-2019, 03:44:35 PM
Mike Otis Mike Otis is offline
I have one like that found a crank for it on ebay
Old 03-24-2019, 10:32:34 PM
Images: 160
Hereís a photo of my 1937 AG. It turns over, but Iíve never tried to run it.
They must not have made very many of these earlier engines. They donít turn up very often at all.
Old 04-05-2019, 08:23:38 AM
Doug Tallman Doug Tallman is offline
Does anybody know for sure when the early squared off shroud was replaced with the shroud with the edges rounded on the front? Maybe a serial number break for the change?
Old 04-05-2019, 04:17:23 PM
Images: 160
Default Re: could someone tell me if this is an early Wisconsin engine
Good question, Doug! My gut feeling is it was around 1939 or so, but Iíve never really done any research.
Old 04-05-2019, 06:13:33 PM
I'm thinking 39-41 range but have been trying to narrow it down. It seems like it happened when they went from the 2 digit model designation to the 3 digit. Kind of wondering if it happened between the 5 digit serial and the 6 digits. I don't have any 6 digit numbers with a square shroud or any 5 digits with the rounded ones. I'd also like to find a date chart for the 4 digit numbers.
Old 04-08-2019, 04:53:44 PM
https://www.youtube.com/watch?v=D2fUqW6bG2g
Very early Wisconsin turbo Wisconsin Engines 16 11-14-2016 09:23:21 AM
Wanted: early 1930's Wisconsin D-4 6 cylinder gas engine Mainesteam Antique Autos and Trucks 10 08-14-2016 03:38:02 AM
looking for info/id early WISCONSIN AKS engine johnnyrock70 Wisconsin Engines 1 10-07-2014 12:31:57 PM
Early Wisconsin information? David Babcock Antique Gas Engine Discussion 1 02-27-2009 05:54:08 PM
Early Wisconsin Engine David Babcock Antique Gas Engine Discussion 4 08-03-2007 10:14:51 PM
