Wisconsin Engines
Wisconsin THD Stator question
this thread has 1 replies and has been viewed 142 times
Old 04-11-2019, 12:34:15 AM
laserfixr laserfixr is offline
Default Wisconsin THD Stator question
I have an old Wisconsin TJD that has an internal ground connection halfway between the two stator output wires. My separate regulator (YJ60) and separate rectifier module (YJ68) are both bad but the stator outputs 46 VAC when running, Can you recommend an all in one regulator-rectifier module to use and how to wire it up to my center tapped stator windings? Thanks very much.
Old 04-11-2019, 08:52:52 AM
I like oldstuff I like oldstuff is online now
Default Re: Wisconsin THD Stator question
Try something like this, cheap and reliable. Pink and yellow to the stator wires. Green ground, red to the battery. It'll give you 13.7 to about 14.5 volts to the battery depending on the design. Fuse the red DC output at 10 amps.
If you find one with three yellow wires from a 3 phase bike, just use two yellows to the stator.
https://www.ebay.com/itm/Universal-4...frcectupt=true
How do you Check a Stator on a Wisconsin TJD Meco3hp Wisconsin Engines 5 05-12-2018 03:22:54 PM
Just a curious question, Rotor/Stator nothingbutdarts Onan Generators 10 11-21-2017 08:15:25 PM
Stator question James Wallace Small Air Cooled Gasoline Engines 1 12-02-2010 10:21:03 AM
6.3 NHEF Stator Wiring Question addisoj Onan Generators 3 01-25-2010 02:03:09 AM
Stator Winding - Voltage Reference Question Jonathan Onan Generators 2 01-12-2006 01:29:30 PM
