Wisconsin Engines
Wisconsin Single Cylinder Help
this thread has 5 replies and has been viewed 247 times
Old 05-09-2019, 01:32:56 PM
Keith Merchant Keith Merchant is offline
Default Wisconsin Single Cylinder Help
Hi, I would like to know where I can buy a Mag cap & rotor & points for my motor? I can't find them anywhere on line.
I live in Sarasota,FL if there is any place around me I can't find ether.
Any help would be great.
Thanks
MD# BKND
SPEC# 3731A1
SERIAL# 5263522
Old 05-09-2019, 02:50:58 PM
Lonnie Grissom Lonnie Grissom is offline
Default Re: wisconsin single cylinder help
Keith I may have what you need. Post a description of mag like base or flange mt slot or gear driven slant or straight tooth, etc best a model no of mag. Picture if possible.
Old 05-09-2019, 05:01:11 PM
Banner Sponsor
See other identical post
info@mcdonaldcarb.com
Old 05-09-2019, 07:25:16 PM
This came off of a DOT street sign & ran an alt. & lights.
well get some pic's soon, thats all I can do because its still all together.
my brothers son came down & seen it on the bench & said his friend needed a cap & rotor & I told him I'm using it & not taking it apart, I went out day after he left & seen he had taken them anyway. that family for you.
Old 05-12-2019, 04:26:52 PM
Only #s on my mag Are
PrE ID
GW 4408 2F
The out side dia. of mag@ the cap is 64.20mm
inside dia. is 58.86 and this with cheep HFmic.
this came off DOT street sign,, single cyl.
can't get the pic to load
Old 05-13-2019, 02:10:02 AM
PrE ID
GW 4408 2F
Unknown Wisconsin single cylinder A9lewis Unidentified Engines 7 11-10-2018 10:00:32 AM
Wisconsin single cylinder engine from a Yazoo YR60 mower. bolt-on-bandito Wisconsin Engines 15 02-28-2017 01:59:31 PM
Stromberg ML 16 for Wisconsin Single cylinder TractorDom Carburetors, Mixers, Fuel Pumps and fuel delivery 0 11-15-2015 10:15:16 PM
Wisconsin Single Cylinder Rod Lengths Question cubcadet70 Wisconsin Engines 5 09-28-2013 07:50:34 PM
Large Single Cylinder Wisconsin John Schwiebert Wisconsin Engines 12 04-11-2009 08:39:17 AM
