Wisconsin Engines
Looking for Wisconsin TJD
this thread has 7 replies and has been viewed 2357 times
Old 07-07-2015, 11:17:19 AM
aort11 aort11 is offline
Default Looking for Wisconsin TJD
I have a J20 Ditch Witch that had a rod come through the side of the block. It had a TJD engine in it. Is there anything made today to do an engine swap to some other 2 cyl modern engine? If not, I'm looking for a replacement TJD if anyone has one or knows of one. I'm in east central Indiana.
Old 07-18-2015, 12:52:35 AM
Geoff H Geoff H is offline
Default Re: Looking for TJD
i have one! just picked this one up about a week ago,i can take pics if you need ,ill be in the shop tomorrow,north chicago 224-243-0765
Old 07-18-2015, 10:30:46 AM
K-Tron K-Tron is offline
I'd first address why the engine failed before fitting another engine.
Were you running the machine on a very steep angle (i.e. oil starvation), Does the machine get regularly used? (if sitting too long the check balls in the oil pump will stick and the engine will run without oil pressure) Was the engine low on power, and someone wired the governor all of the way open? Does the piece of machinery sit in a dirty barn? (mouse nest in the air shroud)
The TJD is a tough engine, you can beat the snot out of one all day long, and it wont mind. As far as im concerned there are only three ways for a rod failure to occur in that engine; overrunning the governor, failed oil pump, and clogged air fins causing a piston/cylinder seizure.
Chris
Old 07-20-2015, 01:33:26 PM
It doesn't get used often. It has just been used every 3 or 4 years for projects. It had the oil and gas changed. The governor was adjusted correctly. Air shroud clean. Upon looking a little closer, the nut was missing from one of the rod studs, I'd say it worked itself loose somehow.
Old 09-22-2015, 07:40:44 PM
autoteck autoteck is offline
Default Re: Looking for Wisconsin TJD
I am looking for parts for a tjd How bad is the crankshaft and camshaft damaged in yours, I would be interested in the parts from this blown engine
write me at autoteck1@roadrunner.com and let me know what you have that could possibly be salvaged Thank you Jim Fletcher
Old 10-01-2015, 09:42:18 AM
StoveBolt StoveBolt is offline
Seen a 2 cyl Wisconsin at an antique mall in Fowlerville, mi the other day, try his best to sell it to me, said it runs great, his name is Rick (517) 223-4855
Old 04-12-2016, 03:13:53 PM
nick b nick b is offline
i have a very clean low hours TJD for sale in UK
cheers nick
Old 04-04-2019, 02:25:49 PM
boone007 boone007 is offline
I have tjd wisconsin twin thanks dan !~~
wisconsin ak fatmike Antique Gas Engine Discussion 2 11-14-2014 12:40:25 AM
Two cyl. Wisconsin help ID, no tag... Artyfact Wisconsin Engines 15 09-17-2011 10:33:07 PM
Wisconsin AKN Jim M. Wisconsin Engines 5 11-25-2009 02:06:24 PM
Wisconsin 30 hp v-4 farmer24 Wisconsin Engines 1 04-21-2009 08:58:55 PM
Wisconsin I.D. Walt in Jaxn Tn. Wisconsin Engines 14 05-21-2008 12:52:14 AM
