Metal fuel in in a Powerback Generator maybe?
this thread has 6 replies and has been viewed 381 times
Old 10-12-2018, 07:41:22 PM
Hummer Hummer is offline
Default Metal fuel in in a Powerback Generator maybe?
Was thinking about getting a steel brake line and running it from big fuel filter I have below fuel tank down through the engine and into a short rubber fuel line clamped to inlet on carb. Where the fuel line comes out to the engine there isn't enough room for any filter I know about.
Or better yet a copper line.
I have seen copper screens that go in furnaces but don't know where to get such.
Old 10-13-2018, 05:22:01 AM
Tracy T Tracy T is online now
Default Re: Metal fuel in in a Powerback Generator maybe?
you dont want to use rubber or copper, petroleum will eat rubber! copper will corrode. steel or brass is fine, as for something flexible neopream aka fuel line, its not rubber.
Old 10-13-2018, 08:48:06 AM
Is that the yellow tubing that is available at the parts houses? The hose I have is gas line I got from NAPA. I run my tank dry before it gets put up.
Old 10-13-2018, 09:11:05 AM
gas line or fuel line from napa will be fine, never seen the yellow tubing.be careful where you run it though, dont want to burn it like on a exhaust manifold. that could turn ugly really fast!
Old 10-13-2018, 01:38:25 PM
What sort of "big fuel filter"? Most in line filters are intended for pressurized fuel systems. Gravity feed fuel systems may not flow sufficient fuel through them. As to copper screen that is probably stocked by Mcmaster or Fisher Scientific.
Doc
Now teaching old dogma to new hicks!
Old 10-14-2018, 06:48:42 AM
Thaumaturge, long time since we talked. Before I forget it I got a 1/2 pound of moly powder on Amazon for 55.00 so I am good to go.
The inline filter I have works great on the gravity feed I have. I pulled Powerback out for power failure and got it running and it cut off four times in 4 hrs 55 minutes. I would come out, engage choke, pull it and then open choke again and it would run great.
Finally the little loose pieces from the black fuel line got flushed out and last 2 1/2 hours it ran perfectly fine. First 90 minutes it spit/coughed occasionally and finally it was just fine.
Someone mentioned he stopped this by putting a small filter right up at carb and the powerback just does not have the room.
I have seen the fine mesh screens on tractor carbs but have never seen them for sale.
Was thinking about Tygon fuel line. Could not think of its name till now.
Old 10-14-2018, 09:31:20 AM
they can be had, check out all states ag parts or steiner. they have a few, i was looking in the ford new holland section. i didnt find the one i was looking for but i did run across a few.
PowerBack 5250 watt Generator Question Hummer Generators & Electric Motors General Discussion 37 10-14-2018 07:33:09 AM
Powerback Generator by Devilbiss Phil P Honda, Yamaha, Kawasaki, Isuszu Generators 4 09-27-2017 06:30:55 AM
Metal fuel tank repair Pete Spaco Carburetors, Mixers, Fuel Pumps and fuel delivery 4 07-06-2016 10:21:09 PM
Powerback Generator Do Not Operate Above 104F Hummer Generators & Electric Motors General Discussion 10 08-21-2014 09:03:12 AM
Factory recall on Powerback Generators-cracked fuel tanks Hummer Generators & Electric Motors General Discussion 0 08-06-2014 07:45:52 AM
