Getting crud out of Powerback Gen fuel tank
this thread has 0 replies and has been viewed 214 times
Old 10-14-2018, 11:22:13 AM
Hummer Hummer is offline
Default Getting crud out of Powerback Gen fuel tank
I ran it dry and then put paper towel in long need nose pliers and soaked up the gas left about the fuel opening.
Thought about vacuum and it hit me. Went in my shop and got a 30 cal cleaning patch. Wiped GAA (Grease Arty and Arty) which is light tan and synthetic.
Clamped it in long nose pliers and pushed the patch in a daubing motion and pieces came out. Had to regrease the patch the final time and I got every piece of crud in the tank ! ! ! !
Looking at it closely it appears to be pieces of the plastic fuel tank and some other crud but I was sure proud to see it was all gone.
Will be interesting to see if there is any more. Will probably crank it off and put about 3000 watt load on it this afternoon.
Metal fuel in in a Powerback Generator maybe? Hummer Carburetors, Mixers, Fuel Pumps and fuel delivery 6 10-14-2018 09:31:20 AM
Galloway in UK - Tank cooled, fuel tank position? Neale Pryce-Hughes Antique Gas Engine Discussion 4 06-28-2016 10:22:37 AM
Factory recall on Powerback Generators-cracked fuel tanks Hummer Generators & Electric Motors General Discussion 0 08-06-2014 07:45:52 AM
Fuel tank - desolder tank halves to repair? KD5BYB Small Air Cooled Gasoline Engines 8 12-04-2011 06:08:58 PM
2-71 loss of fuel pressure from fuel tank-check valve? or bad fuel pump? Walter J. Generators & Electric Motors General Discussion 18 08-24-2011 09:22:40 AM
