Go Back   SmokStak > SmokStak® Old Iron and Tractor Community > Farm + Industrial Antiques and Collectibles
Farm + Industrial Antiques and Collectibles Old belt driven farm equipment: shellers, milkers, threshers, pumps and antiquities of the industrial revolution.
Making power belts from leather
this thread has 13 replies and has been viewed 925 times
Old 03-13-2019, 01:44:54 AM
RustyNumbat RustyNumbat is offline
Default Making power belts from leather
I've had a bit of a search online and on the forums but I can't find any guides for making machinery belts out of leather! I've got a Lister D and old milking vacuum pump I hope to have ready for the weekend, but no belt to suit the two. I do however have loads of full thickness leather and leather working gear (studs etc)
Is it worth making up a leather belt, and does anyone have advice? I'd only be running the pair at the odd show a few times a year..
Old 03-13-2019, 07:52:23 AM
anthony k axsom anthony k axsom is offline
Default Re: Making power belts from leather
Why not should work. Old metal lathes and machining tools use leather all the time.
Old 03-13-2019, 08:43:52 AM
I am not sure if you are talking about making belting from hides or lacing a belt that you already have but I use only leather belts for my lineshaft machine shop. I use Clipper lacing to join the ends.
Old 03-13-2019, 06:31:15 PM
Making a new belt from leather Bill. Cutting a belt to size is easy, I guess I just don't know how to join the ends, if the leather should be oiled etc etc
Old 03-13-2019, 06:40:22 PM
New leather should not need any treatment. On old leather I use 2 parts lard to 1 part cod liver oil and apply while hot. The ends of the belt sections should be skived and glued. I don't know what they use for glue but I have used melted gelatin to glue clean leather and it worked great.
Old 03-13-2019, 07:28:16 PM
Frank DeWitt Frank DeWitt is offline
I agree, I have a belt I had made by a local shoe repair shop, for a old air compressor. It was skived and glued. Worked great.
Old 03-14-2019, 06:03:02 AM
Skived? What do you mean by that? I have a tin of Foss leather cement, which is fine for shoes and such but I would have thought the forces a belt is under would require some rivets or staples or something...
Old 03-14-2019, 06:43:33 AM
eddie bedwell eddie bedwell is offline
Hi Team,
here is a link to an article on splicing/lacing leather drive belts--I Googled "how to lace leather drive belts" and this was one of several that came up.
There have been numerous Threads on belt dressings, lacing, splicing and care on here over the years--some of these appear in a box at the bottom of the page.
https://www.farmcollector.com/equipm...ce-a-flat-belt
Hope this helps--if not keep asking questions and you will surely get some more help.
Saw a nice lacing job a mate had done on his pump drive belt as displayed at our recent MSTEC Club Steamfest Rally here in Melbourne
http://www.melbournesteam.com.au/steamfest.html
Hope this helps.
Cheers,
Eddie B.
The Following User Says Thank You to eddie bedwell For This Post:
Old 03-14-2019, 07:27:31 AM
Skive means to shave. In glue-splicing a leather belt, both ends of the belting are carefully shaved to taper the thickness from full thickness out to nothing over a relatively long distance. The two ends are shaved from opposite sides and in equally-long tapers so that when they are joined, the splice is uniform. There is a reference as to how long the taper should be for a given thickness, but I'll have to hunt. It has been a very long time since I glue-spliced a leather belt. The taper for 1/8" belting is something on the order of four inches, if I remember. An old machinist once told me that he was taught in machinist's school to never use a laced belt on a lathe. The belts were to always be glued because the lacing passing over the pulleys would leave an imperfection in the machined surface. How true that is, I don't know; that's what he was taught in 1946.
I, personally, prefer a glue splice on leather. If nothing else, it just looks nicer.
The Following 3 Users Say Thank You to Kirk Taylor For This Post:
Old 03-14-2019, 08:37:55 AM
Here is a South Bend Lathe Works bulletin on belt splicing:
https://wewilliams.net/docs/Belt%20S...20No%20600.pdf
Old 03-14-2019, 12:51:27 PM
Junkologist's Avatar
Images: 160
Always remember that the hair side of a leather belt runs on the pulley, not the flesh side. This is something I donít usually see mentioned when talking about leather belts.
Mike
SmokStak member #146
The Following 3 Users Say Thank You to Junkologist For This Post:
Old 03-14-2019, 11:40:13 PM
mihit mihit is offline
Hide glue or animal glue ( of which gelatin is one) - generally all the hooves and hides boiled down in a hot pot. Powerful stuff.
Generally dealing with stuff you use "like with like", animal products with animal products, plant with plant, plastic with chemicals.
ie leather gets treated with neatsfoot and glued with hide glue, while canvas gets treated with rape or flax oil, rubber is vulcanised etc.
---------- Post added at 04:40:13 PM ---------- Previous post was at 04:21:48 PM ----------
I've heard the story too, for clipped belts rather than laced, but never seen any corroborating turns.
I like the rhythmic "click CLICK click CLICK click..." of a clipped belt.
Now, a gear driven thing with a high spot on the pinion, watch out!
Old 03-20-2019, 03:45:59 AM
Here's a highly scientific diagram I made up, side-on view of these methods as I understand them.
I thought of trying the third one, where I use a fairly short half join and use both glue and leather studs to hold the overlap together.
On second thoughts, the leather I have is only about 3mm anyway, and I'll only be running the gear as a demonstration so I think I might just overlap them and glue/rivet as they are.
Old 03-20-2019, 05:06:00 AM
Well I bit the bullet and decided I should actually try to learn some new skills, so laced it is! Going well so far, this is a fairly calming activity once I learned I needed to tidy my work space and clamp the belts in place....
Had to make the four "finishing" holes a 5mm punch instead of 3, to accommodate so many passes of the thong. Has come together pretty well, though the outer passes are a little loose. Looking forwards to getting the other two done. Then I'll have a belt, and be relying on the positioning of the pump and engine to give it tension.
The Following 3 Users Say Thank You to RustyNumbat For This Post:
Power Transmission by Leather Belt 1914 David Hoover Steam Stationary Engines, Traction Engines, Steam Boats 0 01-23-2019 12:36:55 AM
Need HELP! Making endless belts Rick McKay Machine Shop and Tool Talk 3 09-24-2007 01:28:15 PM
Leather drive belts? TomHolloway Steam Stationary Engines, Traction Engines, Steam Boats 15 09-04-2007 04:04:27 PM
Leather drive belts? TomHolloway Antique Gas Engine Discussion 2 04-09-2006 10:23:30 AM
Making flat belts from conveyer belts Ihorse Antique Gas Engine Discussion 7 12-03-2005 11:01:16 PM
