Wisconsin Engines
Wisconsin THD 1962 Rescue from Scrap yard
this thread has 4 replies and has been viewed 284 times
Old 03-23-2019, 04:13:30 PM
Colin O Colin O is offline
Default Wisconsin THD 1962 Rescue from Scrap yard
I recently purchased a 1962 Wisconsin THD engine with a 3" Gorman Rupp water pump from a scrap yard for $200.00. Took it home removed the pump, connected it to an 18000 watt pto generator. Had to convert it from propane to gas. Found a used carburetor on ebay and got it for a bid of $2.99. I am not joking! It was an original. Just bolted it on no cleaning and it fired right up, rust, dirt and blue smoke everywhere for the first 5 seconds and then it smoothed right out. The 17 Hp does not give the full 18,000 watts but around 10,000. Enought to run my lincoln 225 amp welder. Replaced all wiring, plugs, new battery and attached a 6 gallon marine fuel tank with a vacuum driven fuel pump of the intake manifold. Generator is an AG Tronic from the late 1970's early 1980's. Any info on the generator would be greatly appreciated.
ID:	331185   Click image for larger version
ID:	331186   Click image for larger version
ID:	331187   Click image for larger version
ID:	331188   Click image for larger version
The Following 2 Users Say Thank You to Colin O For This Post:
Old 03-24-2019, 12:05:52 AM
ulgydog56's Avatar
Default Re: Wisconsin THD 1962 Rescue from Scrap yard
nice find, nice save.....
Old 03-24-2019, 12:09:14 AM
I'm liking the cart.
Old 03-24-2019, 09:27:50 AM
Heins Heins is offline
I like the pump.
Old 03-24-2019, 12:48:23 PM
I like oldstuff I like oldstuff is online now
I'm liking the whole fab job.
Old scrap yard vern0n Antique Autos and Trucks 5 06-30-2012 09:55:23 PM
Engine Info (to rescue from scrap) High Voltage Antique Autos and Trucks 80 10-24-2011 08:37:57 PM
2 Wisconsin v4s at the scrap yard. Michaeljp86 Wisconsin Engines 19 06-11-2009 11:12:00 AM
SCRAP YARD FIND SONNY L Antique Engine Archives 4 08-26-2003 10:22:45 PM
Engine in the Scrap Yard Jon Rozevink Antique Engine Archives 0 05-29-2003 02:47:12 PM
