Go Back   SmokStak > SmokStak® Old Iron and Tractor Community > Farm + Industrial Antiques and Collectibles
Farm + Industrial Antiques and Collectibles Old belt driven farm equipment: shellers, milkers, threshers, pumps and antiquities of the industrial revolution.
IHC 8 inch Burr mill
this thread has 9 replies and has been viewed 509 times
Old 04-06-2019, 05:48:18 PM
Jeremy Hartle Jeremy Hartle is online now
Photo IHC 8 inch Burr mill
Picked this jewel up today. Is there anyway to date these and where would a man find the cob buster for it as mine are missing
ID:	332178   Click image for larger version
ID:	332179   Click image for larger version
The Following User Says Thank You to Jeremy Hartle For This Post:
Old 04-06-2019, 11:25:16 PM
ulgydog56's Avatar
Default Re: IHC 8 inch Burr mill
I can date it ...old....lol. hey nice find, gonna most likely
be hard to find parts for that. good luck..
The Following User Says Thank You to ulgydog56 For This Post:
Old 04-07-2019, 12:38:04 PM
I figured as much . I guess i can plug the holes off for time being until i stumble onto them.
Old 04-07-2019, 04:40:24 PM
Tom Trainor Tom Trainor is offline
Very nice indeed, did the damage to the hopper in #3 come from lifting it without a spreader bar or was it already that way? Again very nice Tom
The Following User Says Thank You to Tom Trainor For This Post:
Old 04-07-2019, 07:41:36 PM
No it was like that when i got. But im sure thats were it come from.
Old 04-08-2019, 12:45:33 PM
Jebaroni's Avatar
Jebaroni Jebaroni is offline
If you give me some of the part numbers from the castings, I can at least narrow it down to a date range. You have a Type "D" machine that was made in 8" and 10" sizes (diameter of the grinding plates). The spiral rollers are not necessary unless you are trying to grind corn that still has the leafy husk on it. The rollers would slice the husks so that they would not clog up the opening where the corn is fed into the grinding plates. The auger in the bottom of the hopper would bust the cobs into smaller chunks that the plates can grind.
The Following User Says Thank You to Jebaroni For This Post:
Old 04-08-2019, 08:10:07 PM
256F, 269F,281F. See if these do anything. And thanks.
Old 04-10-2019, 10:05:39 PM
Jebaroni's Avatar
281F: Breaker, Spiral. Used on 8" type D from 1919-1948
256F: Shield, Plate. 1918-1948
269F: Arm, Center box and cross. 1919-1948
Can you get any from the main frame casting, adjustment handle parts or any of the internal grinding plate pieces (castings the plates attach to)?
---------- Post added at 07:54:27 PM ---------- Previous post was at 07:48:46 PM ----------
Interesting to note that the steel grease cups (number 0 or number 1, not the cast iron ones) are listed as being used with part 269F beginning in 1934, although there appears to have been an earlier grease cup design (with a cover?) that was used from 1919-1925 or 1933 depending on the style.
---------- Post added at 08:05:39 PM ---------- Previous post was at 07:54:27 PM ----------
So the grease cups in question are the cast iron ones. If they are marked S786 on the lid, they were used from 1919-1925. If marked S3983, those were used from 1919-1933. The problem is knowing if the cups are original to the machine or installed after the fact by a previous owner needing extra/spare parts. Later machines (I assume) would have used all steel grease cups similar to the ones found on engines.
I hope all this helps in some way!
Old 04-11-2019, 07:28:00 PM
Grease cups are s786. I dont know if original but patina matches. Try 102F or 39F
Old 04-12-2019, 05:50:13 PM
Jebaroni's Avatar
102F: Lever, shifting. 1911-1948
39F: Wheel, compressor spring hand. 1911-1923
So this information combined with the earlier parts gets us to a time period from 1919-1923. That's about as narrow a window as you are likely to get. Paint committee decision #19 was given in 1925 and specifies red/green color scheme with blue rollers on the Type D. I'm not sure what color scheme was used on earlier machines, but I have a picture of an early one that was all red except for a blue hopper (image attached). Another belonging to Jim Walker on this site appears to be all red except for (maybe) white legs?
I hope this information helps you out!
Jeb
ID:	332607   Click image for larger version
Burr Mill AZ Gary Farm + Industrial Antiques and Collectibles 2 06-04-2017 11:07:48 PM
5 inch burr grinder, grain sieve construction Jim Gorter Farm + Industrial Antiques and Collectibles 1 09-01-2016 05:09:31 PM
Burr mill ID Kirk-NJ Farm + Industrial Antiques and Collectibles 3 09-04-2014 06:27:00 AM
Burr Mill ID John in Maryland Farm + Industrial Antiques and Collectibles 2 06-25-2011 07:55:41 AM
Another burr mill John in Maryland Farm + Industrial Antiques and Collectibles 1 09-02-2009 11:48:21 PM
