Wisconsin Engines
Ignition Coil in VH4D
this thread has 6 replies and has been viewed 237 times
Old 04-15-2019, 03:39:35 AM
marcin6530 marcin6530 is offline
Default Ignition Coil in VH4D
Hello. I'm Marcin. I'm from Poland amd sorry for my English language. I Have Bobcat 720 with Wisconsin VH4D Engine and my engine have a problem with Ignition system. After a few hours of work, the coil is very hot. 3 coils have already been burned. Currently, I have a coil mounted from an old motorcycle (12v, 2 ohm from primmary) and performs well, but it is still quite hot. In my country, I have a problem with buying parts for the Wisconsin engine. Does anyone know what parameters should have a coil and what resistance?
Old 04-15-2019, 01:43:31 PM
DCamp DCamp is offline
Default Re: Ignition Coil in VH4D
I put a ballast resistor on mine and have not had any more problems.
Old 04-15-2019, 03:33:40 PM
Tracy T Tracy T is offline
what DCamp said. and dont worry to much about your english, you did better than some folks that are from here!
Old 04-18-2019, 03:16:00 AM
Thanks for reply. Somebody tell me what resistence must have ballast resistor? I have been in electrical shop in my city and i dont know who resistor to chose - 1ohms or 2 ohms?
Old 04-18-2019, 01:04:08 PM
The one I use is for a Dodge car circa 1970. When I get home tonight I'll look up a part number.
Old 04-18-2019, 06:32:51 PM
I thing i found problem. Somebody replace the rotor contact of distributor. This rotor in my distributor is to small and can't touch electrodes distrubotor cap. So if between rotor and distributor cap is a gap the electric current have problem with flow.
Old 04-18-2019, 09:53:29 PM
The ballast number is RU-11 from Standard Brand / Blue Streak.
VH4D Ignition Condensor At Auto Parts Store? kc27 Wisconsin Engines 6 09-19-2017 01:18:22 PM
Detroit Coil Company Ignition Coil jmacsuga Magnetos, Ignition Coils and Spark Plugs 8 12-10-2011 11:32:46 AM
VH4D magneto swap to coil dlancin Magnetos, Ignition Coils and Spark Plugs 4 11-22-2010 07:03:20 PM
Interesting coil find: The Chief Super Ignition Coil packrat56 Antique Gas Engine Discussion 3 09-14-2007 09:16:19 AM
