Go Back   SmokStak > SmokStak® Old Iron and Tractor Community > Farm + Industrial Antiques and Collectibles
Farm + Industrial Antiques and Collectibles Old belt driven farm equipment: shellers, milkers, threshers, pumps and antiquities of the industrial revolution.
Lane Shingle Mill Question
this thread has 3 replies and has been viewed 398 times
Old 04-21-2019, 08:58:15 PM
kirwanhall kirwanhall is offline
Default Lane Shingle Mill Question
I am looking for a 36 inch saw blade for my Lane shingle mill and not having much luck but in the process I am getting some difference of opinion as to whether the blade needs to be tapered. Some say a tapered blade works better as per manufacturers recommendation , others say a straight blade works just fine. Any opinions on this?
Old 04-22-2019, 12:10:53 AM
Alastair Geddes. Alastair Geddes. is offline
Default Re: Lane shingle mill question
Not sure about taper or not
a straight blade for it may be from a large mill with a worn out blade just cut in down in size to get what you want.
Look to a saw doctor in a place that mills a lot of timber, maybe in house or have own shop in the town.
---------- Post added at 02:10:53 PM ---------- Previous post was at 02:09:27 PM ----------
I would add a tapered blade may jam, look into it a bit more with the saw doctor.
Old 04-22-2019, 02:35:52 AM
Weezer Weezer is offline
Have run 2 Chase mills one straight, standard blade, might even be an old cordwood saw blade. Other has tapered swaged tooth blade. Tapered blade wants more horse power but cuts straighter. Straight blade tends to wander a bit in harder wood and bends a worrisome amount when you get a jam. Just my observation. I'd get the taper if $$ don't matter. Its heavier of course, so you get more carry thru in knotty stuff if horse power is lacking. The taper also helps avoid jams by peeling the shingle out away from the log.
Jim
Old 04-22-2019, 10:01:07 AM
sawmill7 sawmill7 is offline
Sent you s Private message
Lane Shingle Mill Flatlander 43 Farm + Industrial Antiques and Collectibles 1 04-28-2013 11:55:50 PM
Lane Shingle Machine 1878pat Donald Sechrist Farm + Industrial Antiques and Collectibles 3 08-08-2012 11:36:01 AM
Lane Shingle Mill Donald Sechrist Farm + Industrial Antiques and Collectibles 2 05-16-2012 09:46:15 AM
Lane Shingle mill Paul Forbes Farm + Industrial Antiques and Collectibles 1 06-29-2008 10:39:22 PM
Shingle Mill TABest55 Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 1 03-15-2008 08:56:51 PM
