Go Back   SmokStak > SmokStak® Old Iron and Tractor Community > Farm + Industrial Antiques and Collectibles
Farm + Industrial Antiques and Collectibles Old belt driven farm equipment: shellers, milkers, threshers, pumps and antiquities of the industrial revolution.
Need drawings or tech data on a Deming Pump
this thread has 9 replies and has been viewed 5652 times
Old 11-16-2007, 08:34:50 AM
John A John A is offline
Default Need drawings or tech data on a Deming Pump
Picked up an old Deming Model 1890 pump.
Before I take it apart, I would like to see whats inside.
It is frozen and won't turn over.
It seems like the piston.
Thanks in advance for any information.
John
Old 11-17-2007, 07:17:19 PM
Lindy Lindy is offline
Default Re: Need drawings or tech data on a Deming Pump
Hi John,I have a deming 1890 pump.I don't have any drawings but have had it apart.Initially to restore it about 5 yr.ago and this year to replace crank and rod bearings.Let me know what you need to know and I will try to be of help if iI can.
Name:	Crown Point 2005a.jpg
Old 11-20-2007, 11:48:10 PM
Lindy,
Thanks for the response, i have been out of town and haven't had a chance to get to my e-mail.
I probably won't be able to tear into the pump until after the holidays. (Have a few honey do's to tend to.)
I will probably have to bother you with a question or two then. If you don't mind.
I filled the water side of the pump with oil and capped it. It had a fair amount of rust inside and felt it might penetrate or work something loose.
Thats a fine looking setup in the photo you sent.
Thanks again for the reply.
Have a great holiday season.
John
Old 12-05-2007, 08:50:49 PM
rambill rambill is offline
ive got two and there a basic piston pump. theres nothing that you will run into thats very complicated, the biggest problem i had is getting the machined surfaces back flat. you can make or order most of the parts youll need. its probabaly just full of rust and in need of a cleaning out.
Old 07-06-2008, 02:25:14 PM
a327cowboy a327cowboy is offline
Lindy, I am working on a 1890 marvel, and am missing the nut assy to hold the tank bell on.Can you send me a close up photo of yours , so I will know what I need to look for? Also during disassembly I broke one of the valve screw bolts, any Idea where I can find any parts for this pump? Thanks for any help....Bill
Old 06-03-2010, 06:07:06 PM
Deming Pump guy Deming Pump guy is offline
Hi,
I am new to the forum but have an extensive library of Deming catalogs and maintenance manuals. If you are still interested, I also know of an old well/pump guy near Akron OH that has parts for this style pump.
Let me know and I will scan and upload pages from the manuals if desired.
Old 07-06-2010, 06:56:44 PM
redbaron2 redbaron2 is offline
Deming Pump Guy - I just came across your post.
I have an old Deming 1890 pump in my basement with an electric Frigidaire 3140 motor attached to it.
They both need servicing before I can run them.
Do you have manuals/documentation on the Deming pump that you could send me? I haven't been able to track anything down on my own.
Old 10-02-2011, 09:12:35 PM
deny deny is offline
Question Re: Need drawings or tech data on a Deming Pump
I have one of these in my basement that seems to be in pretty good shape.
It has a relatively modern 1/3 HP Dayton Electric 5k444 motor attached.
Probably has not been run in 15-20 years, but the flywheel moves freely. Nothing seems to be frozen up.
Any words of wisdom (or experience) before I try to start it up?
Anything I need to lubricate, prime, or inspect?
Old 02-24-2019, 02:37:47 PM
Lloyd Hardee Lloyd Hardee is offline
John
Hello, john, could you tell me the proper size leather cups for the marvel 1890, including the center hole size. Thanks, i really like this early types of machinery. I have just got my hands on this pump and want it to return to its original glory!
---------- Post added at 01:19:40 PM ---------- Previous post was at 01:11:06 PM ----------
Hello! I have just bought a marvel 1890, looks pretty good, but i suspect may need new leather cups. Do you know the o.d. measurement and center hole size? I really appreciate it! Lloyd
---------- Post added at 01:37:47 PM ---------- Previous post was at 01:19:40 PM ----------
Hello, i need the leather cup size including center hole size for the deming marvel 1890, thanks!
Old 03-18-2019, 01:30:25 PM
Hello, does anyone know the leather cup dimensions for marvel 1890? I cant find much info. David H.
Need operating instructions for Deming New Marvel water pump Rick I Farm + Industrial Antiques and Collectibles 10 05-29-2015 06:45:13 AM
Deming Marvelette parts Pondmaster Farm + Industrial Antiques and Collectibles 6 01-31-2012 12:39:57 AM
Deming Piston Pump Mike S Antique Gas Engine Discussion 5 06-27-2010 11:44:39 PM
Deming Oil-Rite well pump starmanjb Farm + Industrial Antiques and Collectibles 0 06-12-2007 08:56:12 PM
deming co bernie niemeyer Antique Engine Archives 3 11-03-2004 01:33:44 AM
