this thread has 4174 replies and has been viewed 272923 times
Old 01-19-2013, 10:45:13 PM
allis327 allis327 is offline
Default What Have You Done to Your Onan Generator Today?
Maybe this will take off, maybe it won't or has been done.
I ran my 4cck under 90% load for 3 hours today then did an oil change. Ran great under load everything was in specs until I unplugged my stuff. Everything climbed (volts/hertz), throttle was closed as far it would go adjusted the carb and got everything back down. I also learned I need to buy more heavy duty cords if I want to be really prepared.
Old 01-19-2013, 10:50:42 PM
Kpack
Default Re: What have you done to your Onan gen today?
Didn't get to play my gen today was trying to figure the wiring out on my daughters horse trailer.
Old 01-19-2013, 10:54:16 PM
Today, I did nothing except look at my RDJC with appreciation.
The Following 2 Users Say Thank You to Wayne 440 For This Post:
Old 01-19-2013, 10:56:20 PM
Onan Dan's Avatar
Onan Dan Onan Dan is offline
Wink Re: What have you done to your Onan gen today?
Sounds like the 3 hour run time and the 90% load did the CCK good. got er warmed up good and probably cleared out all the old fuel etc and you picked up on your rpm,s so you had to slow her back down to 1800 rpm. me i am working on a CCKB onan i am trouble shooting got no spark, but getting close got lots of good help here on the stak.
Old 01-19-2013, 10:59:29 PM
I worked on getting some of the old oil and crud off my newly acquired 44H, which looks an awful lot like an OTC.
Brake clean is doing a good job so far.
Also dug out a new set of wheels to replace the tiny lawn edger wheels on the cart.
The Following 2 Users Say Thank You to Ed Sparks For This Post:
Old 01-19-2013, 11:12:32 PM
rmchambers rmchambers is offline
I did nothing today to the generator but I did put an outside outlet box to run power from the gen into the house to my inverter without having to open the basement window. It was a bit of a PITA but it will make life easier in the long run.
The Following 2 Users Say Thank You to rmchambers For This Post:
Old 01-19-2013, 11:26:56 PM
AndersonMillTexas AndersonMillTexas is offline
I set up the exhaust on my 7.5 Jb. Also, installed A thru wall vent. Tomorrow I will find a place to set the battery. Then hopefully give it a long run, check the specs and make some fine tuning.
The Following User Says Thank You to AndersonMillTexas For This Post:
Old 01-20-2013, 12:36:45 AM
len k len k is offline
Looked at my AC regulator sitting on a table, wondered when I would get a chance to fix it,,,,,,,,got over it, went to store for food and beer.
The Following 2 Users Say Thank You to len k For This Post:
Old 01-20-2013, 01:08:32 AM
John Newman, Jr.'s Avatar
"....until I unplugged my stuff. Everything climbed (volts/hertz), throttle was closed as far it would go....."
I hope you are not using your idle stop screw to set the no-load engine speed (1800 RPM). That speed should be maintained by governor action only. You should be able to manually move the throttle down to an acutal idle (do this only with NO loads conneted to the generator). Sounds like once it got warmed up it wanted to run considerably faster than it should because it could not close the throttle down.
John Newman, Jr.
Saint Louis, MO
I Can Probably Fix That
The Following 3 Users Say Thank You to John Newman, Jr. For This Post:
Old 01-20-2013, 05:02:42 AM
Billy J Shafer's Avatar
I like the way you think.
