this thread has 4418 replies and has been viewed 294125 times
Old 11-01-2015, 04:14:13 PM
Default Re: What have you done to your Onan generator today?
Dragged the DKD out, installed new fuel filter, got some new diesel with lubricity addative put in it and fired the bad boy up for an hour.
I can only load it with about 23 amps per leg, (using only the two big burners on a house stove) anything more than that and it smokes like a freight train and the RPM just start going down. Not happy with that though. However I do live @ 8,700' so loss is expected especially on a naturally aspirated diesel. I have yet to play with timing to see if it might help.
Oil pressure started @ 60 psi and by the end was about 28 psi.
I was not charging the battery at all, I'll have to check into it's tiny alternator and see why.
Happy Day All!
Old 11-01-2015, 04:19:47 PM
Vanman Vanman is offline
I believe the deration is 3% per 1000 feet? You're way up there, more than 25% derated. What is the rated capacity? Maybe you should fit a tiny little turbocharger
Keith
Old 11-01-2015, 04:41:27 PM
Kpack
Happy Day All!
How many amps is it rated to pull full load ?
Old 11-01-2015, 05:07:11 PM
Onan Dan's Avatar
Onan Dan Onan Dan is offline
Question has any one tried one of those digital Photo Laser Tachometers non touch RPM meter ? would be simple to check the Onans engine speed if they work?
Old 11-01-2015, 06:04:26 PM
Haven't tried a non touch one, but I have a nice old one that consists of a small generator with a variety of rubber drive tips, a removable cord, and a dual range gauge, all in a nice case. Does 0 - 2500 rpm on the low scale and 0 - 5000 rpm on high.
I held it up to my Kohler and it indicated 1300 rpm. Put the Fluke on it and sure enough, 65 cycles....
Keith
  #1936
Old 11-01-2015, 08:16:25 PM
Jim McIntyre's Avatar
A DKD is a 7.5 kW set. 23A at 240V is 5.5 kW.
75% of 7.5 kW is 5.6 kW. So there you go....
The Following 2 Users Say Thank You to Jim McIntyre For This Post:
  #1937
Old 11-01-2015, 08:22:05 PM
Kpack
So do you think that altitude is affecting Jim.
Old 11-01-2015, 08:31:13 PM
BigBlockChev's Avatar
With no touch you should use a bit of sticky reflective tape on the rotating bit. They work by detecting the reflected beam from their light source. If there are key ways or shaft flats and such you have to play around to get a true read. Usually they will read some multiple of the shaft speed. Like 2x or 3x. Sometimes you can just file a shiny spot on the shaft. Cheers Dan
It's always something simple.
If some is good and more is better then too much is just enough
The Following User Says Thank You to BigBlockChev For This Post:
  #1939
Old 11-01-2015, 10:11:27 PM
So, what do you guys think, would a 7.5JB or a 7.5 DKD have more available amp. output at the same 8,700' altitude or should they both be about the same.
Old 11-01-2015, 11:09:59 PM
I don't have enough experience with DKD's to know. I have one, and as I recall it maxes out at a touch over 7.5 kW. IOW, not a lot of margin. I do not know Onan de-rated them at altitude...
My JB (running on gasoline) will do 10 kW at our altitude, so it seems to have more margin than my DKD.
