this thread has 4169 replies and has been viewed 272727 times
Old 01-18-2017, 09:33:56 PM
Mike57 Mike57 is offline
Default Re: What Have You Done to Your Onan Generator Today?
Thanks! I still have to get it painted and put the tags on, probably this spring. For the JC guys, here's some run data off the meters at 12 KW: Exhaust air runs 140 to 180 depending on OAT. Cylinder head temps will go 240 to 300(this is with the sensor on a head bolt) depending OAT, Vacuum is at 8" (at Dallas,TX elevation), Gas pressure is at 11" at idle and drops to 8 under load(fed by a 2psi system with a regulator at the JC dropping it to 7-11"), Oil temperature-takes 3 hours to get it to 180F (full synthetic), oil pressure 35 on the Onan gauge, 25 on the electric, EGT 1150 to 1200F leaned out, A/F ratio-17.2 is supposed to be ideal for NG engines, I'm at 15.3 for best vacuum and best EGT. I keep 1/4 amp + rate on the charge meter.
The Following 4 Users Say Thank You to Mike57 For This Post:
Old 01-22-2017, 05:42:40 PM
zuhnc zuhnc is offline
4.0CCK-3CR/8100R, G750960019 - Load test a week or so ago. NG, electronic ignition, electronic governor, tri-fuel carburetor. Picks up the load reasonably well. Does any one know approximate exhaust manifold temperatures? I have about 100*F difference between the two cylinders.
Old 01-22-2017, 08:21:41 PM
MBB MBB is offline
Sure it's running on both cylinders?
Old 01-23-2017, 09:23:30 AM
Esteban32696 Esteban32696 is offline
i " patted " my 2.5 LK on the head yesterday, before the storms started passing through here !
Old 01-23-2017, 06:32:39 PM
Shorted Out Shorted Out is offline
Worked a bit on my 12.5 KW project. Mounted Air cleaner. Discovered that OEM coolant recovery tank won't fit. Does anybody know if size is critical or mounting height?
Old 01-23-2017, 06:35:09 PM
Computer crashed so lost picture (I guess). 12.5 KW project.
The Following 2 Users Say Thank You to Shorted Out For This Post:
  #2837
Old 02-02-2017, 01:40:12 AM
yellowlister yellowlister is offline
Email NOT Working
Question Re: What Have You Done to Your Onan Generator Today?
Not an onan... but the right shade of green.. picked up two lister ts2 8.5 kw 120 240v 1800 rpm gennys.. had to pull one out of the light tower.. other one I dragged home after splurging for new tires.. has been sitting about 15 years.. they stated and ran fine when they were donated to use on.there soccer field.. but.people complained about the diesel smell so they just used the lights plugged in to city power.. one has 789 hours and the one in the truck has 677 hours
Story is these were from a peach and Walnut farm in Palm Springs.. and donated to the church is bought them from.. 400 for both. 135 miles each way..
Should be a fun project.. plan on keeping one and may sell the light tower unit if both are easily made to run.. but after sitting 10 plus years well see.. still has diesel in the fuel filter so hopefully the injectors are not stuck..
ID:	273743   Click image for larger version
ID:	273744   Click image for larger version
ID:	273745   Click image for larger version
Old 02-02-2017, 02:09:14 AM
Vanman Vanman is offline
"The Diesel smell"? I LOVE that smell!!!
Old 02-02-2017, 06:55:21 AM
JohnnyC JohnnyC is offline
Nice! How many does that make for 2017? 23 gennys
JohnnyC
New Jersey
Old 02-02-2017, 08:13:45 PM
Email NOT Working
I think these are 3 and 4.. but number 2 was free.. and I sold number 1
