1955 US NAVY Mobile Machine Shop Trailer with Schramm/KatoLight 5kw
this thread has 15 replies and has been viewed 1814 times
Old 04-11-2018, 12:17:41 AM
Default Re: 1955 US NAVY Mobile Machine Shop Trailer with Schramm/KatoLight 5kw
Not on my K International, the bowl is down and looks exactly like the one in the picture. I guess in a different application they might run bowl up.
My guess is the basic casting is used in a lot of different applications, and used with different arms etc to meet the application.
Old 04-11-2018, 08:34:08 PM
Motorhead's Avatar
Motorhead Motorhead is online now
That is a sweet old machine! Looks like the two center cylinders of the engine are the compressor and the two outer are the engine driver of everything.
My 1939 WILLYS Pickup.
Bought in 1971
The Following User Says Thank You to Motorhead For This Post:
Old 04-12-2018, 01:50:33 AM
Yeah! I love the firing order with the "0"s in there in place of 2 and 3! How many kw is the generator?
Old 04-28-2018, 02:06:59 AM
ms68sprint ms68sprint is offline
It's a Katolight 5kw.
The Following User Says Thank You to ms68sprint For This Post:
Old 04-28-2018, 02:48:34 AM
For the fuel pump I'd just sub a low pressure electric and be done with it. Make sure you look for a "low pressure" model, as most others nowadays are aimed at high pressure fuel injection systems. BIG difference in pressure.
Doc
"Don't ask why I write satire. Ask instead how I could avoid it..." - Juvenal
Old 05-27-2018, 07:48:56 AM
Esteban32696 Esteban32696 is offline
These are cool !
http://www.seabox.com/products/detai...e-machine-shop
1955 Caterpillar / Lincoln sae 300 x 2 welding machine mschreiber Welding Shop 10 10-19-2016 08:54:15 PM
1920's or 30's Circus Wagon with small city built inside,Blacksmith Shop,machine shop Jim Martin Scale Model Engineering 2 04-15-2013 11:01:46 AM
Machine Shop Wood Shop Collectors in Michigan and Ohio antiquemachinery Farm + Industrial Antiques and Collectibles 1 03-30-2013 12:12:58 PM
Lowboy trailer with Mobile home wheels vern0n Trucks, Trailers and Hauling for Shows 5 04-21-2010 06:12:17 AM
Trailer rebuild, or what is wrong with using mobile home axles? HalfKeck Trucks, Trailers and Hauling for Shows 7 11-14-2008 09:32:35 AM
