Engine Size for 35 kw Generator End
this thread has 12 replies and has been viewed 7835 times
Old 01-05-2013, 07:50:30 PM
James E James E is offline
Default Engine Size for 35 kw Generator End
OK, so I have been searching the web for someplace that will give me a formula to match generator to engine size. Does anyone know how to figure what hp engine would work for a 35 kw, 1800 rpm generator end. I happen to have a continental diesel rated at 50 hp at 1800 rpm. Is that too small?
Anyone know the way to calculate this kind of stuff?
Old 01-05-2013, 08:24:44 PM
Default Re: engine size for 35 kw generator end
The base rule of thumb is 2 hp per KW.
You can mate that to your 50 HP diesel, but you will run out of HP before you run to KW capacity, which is not an all that bad of a thing to have. Sort of puts an insurance plan in place.Not likely to produce more than 25 - 30 kw, so you won't be likely to let the magic smoke out.
Old 01-06-2013, 04:20:53 PM
cherob cherob is offline
A 35KW generator is 35000 Watts. 1 Horsepower is 746 watts, this means you would need 46.92 Horsepower to get the 35Kw. Not much left over. If the load will run around 20Kw it will work with the odd peak surge, say to start a motor. More horsepower is always good even if you don't intend to use it.
Old 01-06-2013, 05:13:14 PM
cornbinder89 cornbinder89 is offline
you are assuming 100% effecincy in converting from engine HP to electric. It is nowhere near that efficent so he'll run out of engine HP before reaching the limit of the genny windings. Nothing is 100% efficent.
Old 01-06-2013, 06:14:38 PM
25Eagle34 25Eagle34 is offline
Location: Auburn, CA. in the Sierra-Nevada Foothills on the way to Reno
The Military MEP-005A 30KW Generator Set has a White/Hercules Model D-298ER rated at 57 HP continous at 1800RPM. This engine would work but not put out the full 35KW.
Old 01-06-2013, 07:48:27 PM
Power Power is offline
As Ed posted, you need close to 2 HP per kw of continuous output. An engine driven WOT or full rack all day will wear fast. You need a bit of overhead for surges and mechanical wear, or there will be frequent rebuilds to maintain near rated output.
Old 12-01-2017, 01:48:23 PM
wbartlett1 wbartlett1 is offline
I have 26KW PTO generator that I want convert to a GENSET. It has a bell housing with a normal SAE pattern to mate to ( I am hoping) a 4-53 Detroit Diesel (non-turbo) producing approx 170 hp at 1800rpms. Is this too much engine, will it hurt the alternator? I may draw 10-12KW max in an emergency situation if my neighbours don't also plug in.
Wayne B
Old 12-01-2017, 02:50:07 PM
Vanman Vanman is online now
While a popularly repeated rule of thumb is 2 hp in per kw out, this assumes a ghastly generator efficiency, but does result in plenty of extra hp for brief periods of overload, but also results in plenty of extra fuel consumption due to the oversized engine.
Probably fine for small sets that are more likely to see intermittent overload and have somewhat less efficient generators.
Lacking the specified generator efficiency, I find 1-1/2 hp per kW to be a vastly more realistic guess. So to get 35 kw, you'll be needing right around 53 hp, give or take, to drive the generator.
The generator will be somewhat less efficient at less than full load, and at relatively light load it could be as poor as 2 hp per kW.
It'll work just fine, but a 170 hp engine driving 20 or 30 hp load will be very inefficient, unless the engine speed can be lowered approximately in proportion. But the generator must (presumably) run at 1800 rpm. Unless it has a gear drive on it, as most PTO generators do. If the input to that is 1000 rpm, it might just work dandy.
A 170 hp 453 sounds like turbocharged and running at least 2500 rpm. I would think that it might be more like 100 hp at the 1800 rpm required for your generator if it doesn't have the PTO gear drive input. In that case, still way too big IMHO.
But, if this is all stuff you already have, and the usage will be infrequent, it may still make sense for you.
Old 12-01-2017, 03:04:58 PM
Email NOT Working
I have found
35 kW = 3.5 liter engine
To be almost universally true.
Turbocharged is a totally different story. You can get like 2/3 more power from a turbo engine which if this was a diesel would make it a 2 liter turbo but more likely a 2.2 or 2.4 because those sizes are more popular.
Just some general patterns I have observed.
Old 12-01-2017, 04:26:54 PM
Of course being that the Detroit is a two stroke we would need to apply some conversion math.
The working portion of the stroke in a Detroit is said to be around 70% of that of a four stroke engine. Since it's obviously firing twice as often, one can reasonably expect ~1.4 times as much power from a given displacement at any given speed.
So if a four stroke, naturally aspirated, diesel typically delivers 10 kw / liter (I assume at 1800 rpm) we'd expect the naturally aspirated Detroit to deliver 14 kw / liter.
Lets see if this works out. A naturally aspirated 71 series Detroit will be found almost universally coupled to generators that deliver 15 kw per cylinder at 1800 rpm or 10 kw per cylinder at 1200 rpm.
Detroits are American, and are therefore (appropriately) specified in Cubic Inches, a tradition that should remain embraced to this day, but sadly isn't. There are ~61 cubic inches per liter, so a 71 series Detroit should be found to be driving a generator of ~16.3 kw per cylinder, at 1800 rpm. Pretty close!
It then follows that a 53 series ought to do around 12 kw per cylinder, again assuming 1800 rpm. So right close to 50 kw for a 453. I'm not sure what is typical, but I wouldn't be surprised if they were typically running at 10 kw per cylinder, for 1800 rpm sets.
Are you SURE that you have a naturally aspirated 453 that makes 170 hp at 1800 rpm??? That doesn't sound right. I want to say that I recall it being considered reasonable to hop up a 453T to around 175 hp at 2500 rpm.
Generator shed size Riley Generators & Electric Motors General Discussion 11 08-30-2016 06:17:20 PM
What size generator do I need? jcsok Onan Generators 12 02-18-2015 06:43:24 AM
Antique engine size vs implement size Rob Q Antique Gas Engine Discussion 2 04-08-2014 01:59:48 PM
Type and size engine to run a generator? Beez Steam Stationary Engines, Traction Engines, Steam Boats 35 11-30-2009 11:09:09 PM
Generator rated size? Jerry Akins Generators & Electric Motors General Discussion 7 08-11-2008 12:19:27 PM
