MEP 803A Won't Crank at Start Switch
this thread has 2 replies and has been viewed 1299 times
Old 04-15-2016, 07:45:26 PM
bocon bocon is offline
Default MEP 803A Won't Crank at Start Switch
My mep 803a was working just fine. I turned it off and when I went back to restart..nothing at the start switch. It will dead crank and I hear the fuel pump kick in when I turn the switch but nothing at the start position. E switch is out and battle short in off position. Any suggestions as to directions of inquiry would be greatly appreciated.
Old 04-19-2016, 10:54:53 AM
Regenerator51 Regenerator51 is offline
Default Re: mep 803a won't crank at start switch
Try messaging Zarathustra. He might possibly help.
Old 03-23-2018, 01:56:56 PM
bunkclimber bunkclimber is offline
this is an old thread,but just to answer,check the DC circuit breaker inside the control panel..its on a metal tab that sticks out from the inside of the control panel near the tap switch.Somtimes this breaker will pop out or trip if there's a fault in the wiring..sometimes they get weak as well.I'm assuming that you already checked the dead crank switch inside the engine compartment L side door.Best of luck.
MEP-803A Start And Load Test CT-Mike Military MEP and Aircraft Gen-Sets 0 11-19-2015 10:50:18 AM
Onan MDJF stops released start switch Centrifugal Switch Problem Chuck711 Onan Generators 10 01-29-2015 03:22:11 PM
Onan 4k start/stop light doesnt work and stops running when release start switch JoshD Onan Generators 12 09-06-2014 07:51:40 AM
Emergency stop switch kicks out when i push start switch hurdy Onan Generators 9 08-29-2012 07:50:51 AM
Genset 4000 won't crank from the remote switch hackerjoe Onan Generators 24 11-07-2010 10:16:15 PM
