My New PE-197
this thread has 37 replies and has been viewed 3213 times
Old 01-07-2017, 08:11:28 PM
SPBiker SPBiker is offline
Default Re: My new PE-197
Originally Posted by yellowlister View Post
I should of said I watched your new video.. and it sounds really good.. what are you going to do with the other one?
The M5 now belongs to the museum I work at. Im going to be restoring it as well, it will then go on display with our Bofors 40mm antiaircraft gun. Once I start tearing into that one ill start another thread
The Following User Says Thank You to SPBiker For This Post:
Old 01-07-2017, 08:51:41 PM
Cool! I forgot I had a original copied book for it.. and I found the old restate that was in it. If you ever come up this way or I that I'll bring it.. or I can mail it to you. when I could not get it to make voltage I thought it may of been shorted and another one came with it that I installed.. I could only get 3.4vac even though it was getting 6vdc to saturate the windings
Old 01-09-2017, 04:20:20 PM
I was able to find the manual online for the M5. As for the voltage issue, I'm sure I could figure it out. We have a lot of knowledgeable old farts down here where I work
Old 01-26-2017, 02:04:57 AM
Im looking to change back to the original shielded spark plugs and wires. I was wondering if I could use the shielded plug wires from a M151 Mutt (vietnam era jeep). My two concerns are, will the 24v wires from the jeep work with the 6v system on the generator? And the other concern is I dont know if the jeep wires will fit onto the generator magneto.
Old 06-08-2017, 01:45:17 PM
Does anybody know what tags or data plates went on the inside door of the battery box and the underside of the radiator door. Looks like it was some type of plastic riveted to both doors
ID:	283968   Click image for larger version
Old 06-08-2017, 05:29:12 PM
Amax Amax is offline
I love that thing. It is a folded up PE-95. Fantastic! Good luck with it.
Old 06-08-2017, 07:35:06 PM
Thanks Amax, it is a pretty cool generator. It has a Hercules ZXB instead of the Jeep engine inside the PE-95
Old 06-10-2017, 09:00:14 AM
macjeeper macjeeper is offline
None of my PE-197 Generators have the instructions to operate on the exhaust door or on the battery door, but I do have photo's to send you later.
Can't right now, have USAF reserve duty today, got to go in a few.
Mac
Old 06-12-2017, 02:45:27 PM
Thanks a lot Mac, and thank you for your service.
Chris
Old 06-13-2017, 12:12:37 AM
Chris
Only 31 years, retire in December.................yehhhhhhhhhhh
The Following 2 Users Say Thank You to macjeeper For This Post:
