MEP-016A - Newly Aquired - Need some tips
this thread has 2 replies and has been viewed 883 times
Old 10-23-2017, 01:06:56 PM
fordiesel69 fordiesel69 is offline
Default MEP-016A - Newly Aquired - Need some tips
When hand cranking engine I hear an abnormal rubbing sound from the generator area, kinda like a if you have a brush go bad and the holder starts to dig into the comm. Im sure thats not the problem but would like to inspect before starting the engine.
How do I access the area to inspect, it does not seem to have an access panel.
Old 10-23-2017, 04:10:40 PM
dependable dependable is offline
Default Re: MEP-016A - Newly Aquired - Need some tips
Sounds like something may have come loose inside. I know the field plates sometimes came unfastened in the 018's. Here are links to a couple of manuals. In my opinion, these are kind of loud and thirsty, at least by today's standards, but good luck, they are kind of neat.
http://www.liberatedmanuals.com/TM-5-6115-271-14.pdf
http://www.liberatedmanuals.com/TM-5-6115-271-24P.pdf
The Following User Says Thank You to dependable For This Post:
Old 10-23-2017, 04:21:23 PM
These are brush-less units, could be a bearing (older models have an inspection hatch), stator/rotor not lined up properly, or foreign objects from critter-condos.. there are vents for the blower they can get up into. Need to remove the control box for better a look into the rear end.
Newly Aquired. 3.5 Hp New Way Engine. Help needed. ShaneZahn Antique Gas Engine Discussion 5 11-12-2013 09:57:43 AM
Aquired a bit of cable snowshoveler Onan Generators 24 06-06-2013 11:13:45 AM
Newly aquired sandow 1.5 hp? jsfoley Antique Gas Engine Discussion 7 09-24-2012 12:03:45 PM
Newly aquired ELLIS 1/3 Ihorse Antique Gas Engine Discussion 5 02-06-2012 04:44:27 PM
Aquired 12.5-jc control issues not starting chuckster61 Onan Generators 0 10-09-2005 10:38:31 PM
