1943 M5 Generator Three Phase Power
this thread has 3 replies and has been viewed 613 times
Old 12-01-2017, 11:10:59 AM
Steve Mickelson Steve Mickelson is offline
Default 1943 M5 Generator Three Phase Power
I have a couple of M5 generators.First off I am not an electrical person,I know you can get 125 volts by connecting any two leads.My question is could you use a 3 phase transformer 220-440 connect to the 220 taps with the 125 from generator and get 220 3 phase.I have read that these generators are not configured like normal 3 phase can anyone shed some light on this for me?Have looked at most of the threads here and not seen that anyone has done this.Thanks in advance.Steve
Old 12-02-2017, 07:26:34 AM
Rich Mc Rich Mc is offline
Default Re: 1943 M5 Generator Three Phase Power
The generator is wound as a "Y" configuration, the voltage per coil internal is about 72 volts and the neutral or common connection is buried inside the stator housing.
A 3 phase step up transformer should work though I don't know how big of a motor one could start off this generator.
The Following User Says Thank You to Rich Mc For This Post:
Old 12-02-2017, 08:33:43 AM
Thanks for the information, if I can find a reasonably priced transformer I would like to try it.I have 2 complete M5's and would like to see them do something rather then just sit and look pretty.
Old 12-02-2017, 02:12:19 PM
Vanman Vanman is online now
Also remember that operating at 1/2 voltage the transformer rating needs to be twice the KVA of the load served, ie operated within it's current rating.
Running Surplus 3-Phase Welders on Single-Phase Power dkamp Welding Shop 47 04-12-2018 11:25:58 AM
120v single phase motor turning 3 phase generator gibbykart Generators & Electric Motors General Discussion 15 10-04-2014 12:00:37 PM
Single phase generator with 3 phase transfer switch? mixdenny Onan Generators 5 06-04-2014 08:26:01 AM
Can a 12 wire generator produce full power in single phase mode? Pete Spaco Onan Generators 5 04-11-2011 10:26:36 AM
US Motor Div Generator Conversion To Single Phase 220V From Three Phase jimybud Generators & Electric Motors General Discussion 4 06-27-2010 08:19:50 PM
