Briggs & Stratton 5020K Ignition Kit
this thread has 4 replies and has been viewed 885 times
Old 01-08-2018, 12:33:16 AM
Military Dave Military Dave is offline
Default Briggs & Stratton 5020K Ignition Kit
I was looking around on line and found this on Amazon. Can anyone tell us for sure if this kit will work in the W.W. 2 P.E. 75 Briggs and Stratton ZZ engine?
https://www.amazon.com/Briggs-Stratt.../dp/B00004RB1C
Old 01-08-2018, 11:15:03 AM
gdstew gdstew is offline
Default Re: Briggs & Stratton 5020K Ignition Kit.
They will not work, they are for much newer engines
Old 01-08-2018, 09:11:55 PM
Do you know where a guy can obtain an ignition kit for the ZZ engine? I would kinda like to have a spare or two on hand.
Old 01-09-2018, 10:40:32 PM
Ed Stoller Ed Stoller is offline
One of my ZZ engines has a failed ignition coil so I converted it to a battery powered ignition using the magneto points and a point saver to switch the Kohler type coil.
Old 01-14-2018, 02:30:41 PM
Bolens 1000 Bolens 1000 is offline
For the points the ZZ takes part $ 291352
Condenser is 29861
I have both instock on my site just type those part numbers in the search box
bolenspartsandsupplies . com
The Following User Says Thank You to Bolens 1000 For This Post:
Briggs and stratton ignition on antique engine? DustyEngine Antique Gas Engine Discussion 5 10-15-2015 07:45:21 PM
Briggs and Stratton 8B Weak Ignition Zen Small Air Cooled Gasoline Engines 23 12-08-2013 12:38:44 AM
Briggs & Stratton 23 Ignition Parts Source ltcpaul Small Air Cooled Gasoline Engines 1 12-02-2013 12:00:27 AM
Briggs & Stratton WI Ignition Wire? sillyboy Small Air Cooled Gasoline Engines 2 02-01-2012 06:39:13 PM
Briggs & Stratton Ignition failure (no spark) jools Garden Tractors / Mowers / Scooters 3 06-03-2011 07:04:37 AM
