Fairbanks Morse Z 3hp restoration questions
this thread has 6 replies and has been viewed 1493 times
Old 10-26-2009, 12:59:15 AM
Matt McGivney Matt McGivney is offline
Default
can you run one on a buzz coil? for a temp fire up?
6 volt or 12 volt?
Old 10-26-2009, 08:24:37 AM
oldironcollector's Avatar
oldironcollector oldironcollector is offline
Default Re: fm z 3hp ignitor without mag
Not a buzz coil. If the engine is ignitor you need a low tension coil, a regular old automotive coil will work fine just use the primary side. Wire the battery negative to the engine base and battery positive to one screw terminal of the coil and the other screw terminal on the coil to the ignitor post. One thing you may need to check however is if the points on the ignitor are normally open or normally closed, if they are normally closed then you will create a direct short when you attach a battery and coil configuration. The engine will run but the coil will overheat and drain the battery quickly.
Denny
The Following User Says Thank You to oldironcollector For This Post:
Old 10-26-2009, 09:07:55 AM
Walt Beeman's Avatar
Walt Beeman Walt Beeman is offline
Default Re: Fairbanks Morse Z 3hp ignitor without magneto
If you use an automotive coil take and short the center high voltage terminal to the coil's metal can, this will help keep high voltage from arcing through the insulation of the windings.
Keep Enjoying Old Iron,
Walt Beeman
The Following User Says Thank You to Walt Beeman For This Post:
Old 10-26-2009, 06:22:34 PM
Default fm z 3hp ignitor connecting rod grease cap
i need a replacement grease cap for the connecting rod. see photo thanks matt
Old 10-26-2009, 06:32:38 PM
Default fm z 3 hp ignitor oiler
what is the orignial oiler for my engine?
Old 10-26-2009, 07:41:17 PM
smgussey smgussey is offline
Default Re: fm z 3hp ignitor connecting rod grease cap
Not original in any way, shape, or form, but we get by with grease zerks on a couple of our engines... and it is easier to just give a shot with the grease gun every now and then instead of taking the cups apart and filling them... and it was cheap for us.
The Following User Says Thank You to smgussey For This Post:
Old 10-28-2009, 05:50:14 PM
Default Re: Fairbanks Morse Z 3hp restoration questions
is the coil a 12v or 6 v? looking for a connecting rod oil cap and the oiler . thanks matt
Fairbanks Morse 118 or 204 questions Alan D. Oil Field Engines 26 11-28-2010 12:00:25 PM
Fairbanks Morse ZC-503 and ZC-346 Questions Christian Berlin Antique Gas Engine Discussion 14 10-26-2009 11:58:50 PM
Fairbanks Morse 3HP ZC Questions Alan James Antique Gas Engine Discussion 0 05-29-2007 03:55:28 AM
Fairbanks Morse 3HP Z Restoration Harry Antique Gas Engine Discussion 12 05-18-2007 10:27:55 AM
Fairbanks Morse 13yr old restoration... (neat) chase Antique Engine Archives 16 02-08-2002 01:47:59 PM
