Honda inverter gen.
this thread has 4 replies and has been viewed 368 times
Old 02-10-2019, 11:24:39 AM
BHoward BHoward is offline
Default Honda inverter gen.
Bought this 1000 watt Hond inverter generator about 16 years ago and now it seems to run at the high speed all the time regardless of load. Still puts out the proper voltage. Anybody any ideas. Thanks. Bill H.
Old 02-10-2019, 11:35:47 AM
Kevin K Kevin K is offline
Default Re: Honda inverter gen.
Maybe the ECO-Throttle switch was left in the OFF position?
Old 02-10-2019, 11:38:20 AM
1936JDB 1936JDB is offline
My Honda clone creeps up over time. I have to adjust the eco idle screw from time to time. But this sounds more like maybe the eco throttle servo might actually be stuck or inoperable.
Old 02-10-2019, 11:55:21 AM
My guess would be that the filter capacitors on actual generator stage have aged and lost storage capacity. All inverter gens have a polyphase generator in front end that is rectified and filtered by large capacitors. DC from these capacitors feeds the inverter section. If voltage on filters drops generator throttles up. Capacitors dry out over time. When they dry out storage capacity is reduced.
Doc
"I could while away the hours communing with the flowers if I only had a brain.."
Old 02-10-2019, 12:32:50 PM
Thanks guys. I like Kevin,s answer best. Some dummy left the Eco switch off, and I think it was Me. I'm just getting old. Thanks again everybody.Bill H.
EU7000 Honda Inverter Kimroy Honda, Yamaha, Kawasaki, Isuszu Generators 2 02-23-2018 01:23:46 AM
Honda EU7000 remote start to inverter wiring AKAviator Honda, Yamaha, Kawasaki, Isuszu Generators 4 12-03-2017 07:37:27 PM
Honda Eu3000is inverter tests procedure? Tomvoegt Honda, Yamaha, Kawasaki, Isuszu Generators 4 12-23-2016 02:46:59 PM
Honda's New Inverter Generator EG2800I AlexV Honda, Yamaha, Kawasaki, Isuszu Generators 14 10-12-2016 01:22:00 PM
Honda EU 6000 inverter generator. Ash fork genetator Honda, Yamaha, Kawasaki, Isuszu Generators 2 03-26-2016 11:17:45 PM
