Myrick Eclipse
this thread has 1 replies and has been viewed 2559 times
Old 01-21-2002, 12:31:42 AM
Vern Barker
Default Myrick Eclipse
Hi hope some of you can help me!I just done some old fasion horse trading Ended up with a 4 HP Myrick Eclipse Fully restored but has a problem with the orginal myrick gas valve which I tink the diaphram is bad.Is there any one making this part? Or does anyone have any idea on what material would work. Thanks Harry You are a god sent to all of us engine nuts. Until next time Vern.Barker
Old 01-21-2002, 11:24:05 AM
Tommy Stojanov
Default Re: Myrick Eclipse
Hello Vern,
Yes, there is a material that you can replace the regulator diaphragm with. Not sure what it is called, but it is some very durable woven stuff. I may have some in old regulators, off roof tops and gas trains. I was curious in trying a rubber material. I assume you are running this engine off propane, correct? If the regulator was never adjusted for propane, and is still set for natural gas, you may need to adjust it. Email me and let me know what you need. See ya.
I want one a these!! An Odd Little Myrick Eclipse Brian Lynch Antique Gas Engine Discussion 17 12-11-2007 09:53:55 PM
Myrick Registry up PaulGray Oil Field Engines & Related Equipment 1 02-21-2006 09:01:07 PM
4hp Myrick or 4hp Oil Well engine weight? Jim Stigerwalt Antique Gas Engine Discussion 2 06-10-2005 12:00:47 AM
4HP Myrick finished. tremel Antique Engine Archives 3 08-05-2004 03:37:47 AM
Luther (Myrick) Eclipse color. Tommy Stojanov Antique Engine Archives 1 01-13-2002 07:15:26 PM
