Oil Field Engines
Olin flywheel question
this thread has 9 replies and has been viewed 1811 times
Old 02-05-2010, 10:11:01 PM
Jeff Davis Jeff Davis is offline
Default Olin flywheel question
I am restoring a 15 hp Titusville Olin engine. The flywheels do not match and would like to hear somone else's opinion. The flywheels are nearly identical except at the hubs. The hub on the clutch side is a one piece "press on" type. The flywheel on the cam-gear side is a split "bolt on" hub. This flywheel also has a counterweight built in.
I have heard a few explanations...........press on flywheels were on the earlier engines, bolt on hubs on later engines.
The "press on" hubs get beat up pretty badly getting them on and off so are the "bolt on" flywheels just an upgraded replacement part?
I have seen another engine with a flywheel set up exactly like mine..........don't know if that is original or not.
Can any other Olin owners shed any light? Thanks..... JEFF
Old 02-06-2010, 09:54:45 AM
Joe Anderson Joe Anderson is offline
Default Re: Olin flywheel question
The early Titusville Olins were press on flywheels with holes in them on one side where the iron was left out instead of adding more weight to one side (counterweight). Two places you can google for some photos are Coolspring P.A. show and there past show pictures and Craig Prucha has a nice webite about his Buffalo Olins. You may allready know but, Olins were built in Titusville and Buffalo and appear to be built under the name Ruger and I have seen one small one built under another name I believe in Chicago (I will look at my pics when I get home). How about posting some pics of the engine. Good luck they are great runners.
The Following User Says Thank You to Joe Anderson For This Post:
Old 02-06-2010, 04:44:24 PM
Jeff Miley Jeff Miley is offline
Beautiful engine. If you do not mind me asking where did you find it? Not alot of oil fields in Suffolk, VA as far as I know. I would love to have one but they have eluded me so far. Both because of scarcity and cost. Good luck with your project.
Old 02-06-2010, 09:42:58 PM
Steve Tachoir's Avatar
Steve Tachoir Steve Tachoir is offline
I have an early Olin and both flywheels are pressed on. They have two ones drilled through the side to counter balance the crank like Joe said.
The Following User Says Thank You to Steve Tachoir For This Post:
Old 02-07-2010, 12:05:15 PM
I got the Olin from Northeastern, Ohio. I wish I had a story about how it was found in a Peanut factory here in Suffolk, but that's NOT the case. The engine was bought in pieces and is still in pieces. Need some better weather and shop space to get it back together. I would offer some photos, but need the wife's help on the computer
Old 02-07-2010, 03:44:45 PM
There is never enough shop space or enough shop time. If another project Olin ever appears and you are not interested please let me know. If my wife is in a generous mood I might negotiate a purchase. Good luck with the project. If you are ever in Salisbury, MD please stop by. No Olins but alot of projects to work on. Bring old clothes and plan on spending a while. There is always plenty of work.
Old 02-09-2010, 08:40:28 PM
Nate S's Avatar
Nate S Nate S is offline
I would agree with the idea that the split hub flywheel was a replacement, because the solid hub flywheels were prone to cracking because they would come loose and then rock against the key and crack the hub along the key way. The titusville olins were built on license from buffalo and were nearly identical except for the valve position, and a few other small changes.
The Following User Says Thank You to Nate S For This Post:
Old 02-13-2010, 08:31:13 PM
Here are the pictures of an Olin style engine I took in Portland in 2008.
ID:	73460   Click image for larger version
Old 02-14-2010, 10:26:14 PM
Nate S's Avatar
That engine was owned by chris austin.
Old 02-15-2010, 10:43:47 AM
Chris Austin's Avatar
Chris Austin Chris Austin is offline
That was an Olin engine, 5 HP. It was kind of a cross between Buffalo,and Titusville Olin. The name on the flywheels was not the maker of the engine, But a manufacturer of flywheels, and belt pulleys. I have seen a catalog of theirs offering all sizes of flywheels. I have also seen a very small, and early Bessemer with the same W A Jones foundry and machine company flywheels.
The Following User Says Thank You to Chris Austin For This Post:
Flywheel question Alan R Hit & Miss Gas Engine Discussion 8 02-20-2007 03:51:24 PM
IH Famous flywheel question. Inter Bloke Hit & Miss Gas Engine Discussion 4 01-14-2007 03:37:23 PM
Olin Question???? 65vette396 Oil Field Engines & Related Equipment 5 12-06-2006 11:42:09 AM
flywheel question Ray Cardoza Hit & Miss Gas Engine Discussion 1 03-01-2006 09:50:50 PM
Flywheel Question Bill Sommers Antique Engine Archives 2 09-01-2002 07:01:32 PM
