Paige Separator Engine (or Standard)
this thread has 1 replies and has been viewed 1337 times
Old 02-28-2009, 09:42:23 PM
Farmall Farmall is offline
Default Paige Separator Engine (or Standard)
Just got a pretty complete Paige separator engine-has the slant fins, Bosch mag, and lever start....but is missing the oiler and I guess, the base because it has four bolt holes on the bottom. Does anyone know what oiler was used and also what the base looked like (or did it have a base?)
Thanks and thanks, Harry.
Old 03-01-2009, 10:30:52 AM
Daniel Dorece Daniel Dorece is offline
Default Re: Paige Separator Engine (or Standard)
Your Paige engine is from a milking machine. It was built by the Standard Separator Co. of Milwaukee. The Paige Co. was located in Chicago. It bolts directly to the milking machine and has no separate base. These machines came with a rope starting pulley or a hand starting lever. The Paige uses a different muffler then the Standard. The muffler is about 2" in dia. and about 4" long and of cast iron. I have seen these engines with several different oilers on them. The only thing common about the oilers is that they are 1 oz. and have screw in filler plugs. Many of them are nickel plated. The bore of all the Paige engines I have been able to measure is 1/8" larger then the Standard engine. Hope this helps.
Iron Wolf
Standard Cream Separator Engine Color? ErikG Antique Gas Engine Discussion 9 08-07-2015 10:52:53 PM
Standard Page Separator engine? Shane Ball Antique Gas Engine Discussion 19 03-14-2015 08:57:49 PM
Standard Cream Separator Engine Kevin Roth Antique Gas Engine Discussion 8 09-21-2009 08:00:30 AM
Standard Cream Separator Engine Question JKKD Antique Gas Engine Discussion 5 12-20-2008 12:28:20 AM
Standard Cream Separator With Engine! David Babcock Antique Gas Engine Discussion 3 04-20-2007 01:56:44 PM
