What to do about blowby?
this thread has 13 replies and has been viewed 34129 times
Old 12-30-2004, 08:36:25 PM
Ken Majeski's Avatar
Images: 46
Default Re: What to do about blowby?
Originally Posted by Mac Leod
I still see no reason for the rings to seat so well and then have blowby a short while later other than the ring gap lineing up...seems to have compression when I turn it over backwards, very little blowby
Well.... I can't see the rings traveling that much that fast. Also if the rings aren't pinned and you reused them you are fighting an uphill battle as they were worn to the cylinder and now they are probably in a different place. I would suspect you are washing the oil off the piston/rings either when starting or by feeding too much fuel. Try feeding more oil and see if that helps. The engine on my saw rig will lose compression ( Has lots Miles on it) if I don't feed enough oil but with enough oil feed it runs Just Fine.... This engine don't just sit there and Put.... It gets worked Hard about 20 to 30 hrs a year.. Yup, one of these days I will have to clean up the ring grooves and get some new rings...
Ken Majeski, Ellsworth Wis.
Old 12-30-2004, 09:54:19 PM
BWegher BWegher is offline
Running at idle or very low RPM ?? This can cause rings to unsettle. Possible carbon interfering, also.
Try running at highest speed allowed for a while. Put at least some load on, and vary it while running high RPM. After a while of that, vary speeds up and down with load. then back to highest RPM.
Old 12-31-2004, 01:22:22 AM
BobRR BobRR is offline
Loose ring lands will let a rings line up the end gaps in less than a hr. of run time.I wish I could find the pict to prove it but wouldnt matter cause ya cant see the engine in that pict. BobRR
Old 12-31-2004, 12:11:44 PM
Images: 46
Well, I have never had the problem of the ring gaps lining up... I do know that the reason they pinned the early rings is because they were made much thicker on the side away from the gap and gravity would actually cause the heavy sides to end up on the bottom and cause the gaps to line up. But modern rings are no longer made that way. How many pinned rings have you ever seen in 2 cylinder John Deeres? and they were certainly successfull. I have removed lots of ring pins and have had no problems. Any compression problems I have ever had have been traceable to wear or lubrication issues.
Engine Blowby TomH Antique Gas Engine Discussion 7 07-26-2005 04:12:01 PM
